R60 Rail Cup Holder Question
Thinking of buying the rail cup holder for my 2014 CM to use as a change holder. There's just nowhere to put change without sacrificing a front cup holder.
I've read some conflicting posts about it not fitting with the e-brake and armrest. Haven't been able to find any pictures though.
Anyone out there have this set up?
Unfortunately, I am travelling and the extra cup holder is home in the garage. But if I remember correctly, the front cup holder can not go in front of the e-brake handle and the shifter. You need to place it on the rail far enough back otherwise when you pull up on the e-brake, the e-brake may rub the side of the cup holder. Additionally, if you have the center armrest, it may not go all the way down.
Again...going from memory
I installed the two rubber cable organizers (bones?) into the rail to make a small box in the rail that can hold coins. It won't hold a lot of money, but it works for me.
Attaching a picture. It's between the phone caddy and the sunglass holder.
For more storage, there are the two areas under the radio/climate control.
i do the same
Ditto this. Works great.
I made use of the rail attachment piece for the sunglasses and mounted a small tray on top of it with two sided tape as per the attached pic. Works a treat and its easy to get coins out of without interfering with anything.
I've done that and my e-brake keeps hitting on the side of the cup, decided to take off and install extra cup holder http://www.outmotoring.com/cupholder-countryman.html
I have manual transmission so it was very annoying to pull e-brake also tried phone holder sunglass holder but no.
Attachment 98913
Attachment 98914
Attachment 98915
Also rotate side to side. Very easy installation although you will have to make a hole to put one screw on. I think 3m tapes will hold it perfectly but for secure i just put on. Very convenience cuz fits any size cups and holds strong.
Attachment 98914
Attachment 98915
Aug 24, 2015 03:14 PM
Kahnfucious
Aug 15, 2015 08:43 PM
