R56 mechanical vacuum pump location?
Old Jul 19, 2014 | 02:20 PM
Gabe3's Avatar
Gabe3
can someone post up a photo of the location of the mechanical vacuum pump and hose I remove so I can see if the knocking sound goes away. I don't want to remove the wrong hose. thanks. from what I've read its near the coolant tank.
does it matter if its removed before or after the car is started?
Old Jul 19, 2014 | 06:01 PM
Systemlord's Avatar
Systemlord
It's that round can looking thing under the intake pipe on the exhaust cam near the turbo. There is also a plastic connecting pipe that leads towards the master cylinder, this is where the master cylinder gets its vacuum, the turbo actuator also runs off the vacuum pump.
Old Jul 20, 2014 | 12:17 PM
Gabe3's Avatar
Gabe3
according to these instructions.
If the noise appears to be coming from the valve
cover or the vacuum pump area, refer to SIM11 02 08. To
verify the source of the noise, disconnect the vacuum
hose from the mechanical vacuum pump to eliminate
the knocking noise.
in the first photo, is it the one with the netting? or is it the one that connects to the top of the pump, shown in the second photo? thanks.
Attached Thumbnails mechanical vacuum pump location?-2014-07-20-14.59.44.jpg   mechanical vacuum pump location?-2014-07-20-15.09.04.jpg
Old Jul 21, 2014 | 04:38 PM
oldbrokenwind's Avatar
oldbrokenwind
Netted hose in 1st pic is for the turbo waste gate. Master cylinder is fed from the top hose --- 2nd pic.
Might try disconnecting both hoses, just be sure not to drive it while disconnected.
Old Jul 23, 2014 | 09:31 PM
Gabe3's Avatar
Gabe3
would removing one and not the other be bad?
Old Jul 24, 2014 | 08:59 AM
Vacuum pump is the second pic.
Just watch unclipping the line at the top, I don't want you to damage that nozzle. Press the clip in on the sides and pull up.
Here is the one for the N14 Turbo Engine which is what you have. ( N14 have the exposed wires / coil ( no top cover ) .
Vacuum Pump 11667556919
http://www.ecstuning.com/Search/SiteSearch/11667556919/
The second one is that main lines , from the bottom of the vaccum pump above to the waste-gate.
http://www.ecstuning.com/Search/SiteSearch/11657570465/
Old Jul 24, 2014 | 12:58 PM
oldbrokenwind
I haven't seen the SIM you reference, so don't know what you're trying to do. For troubleshooting purposes, disconnecting either (or both) hose at the pump should be enough. And, it's easiest to disconnect before starting the engine. You may or may not get a CEL when you start the engine, and definitely don't drive it with the brake hose off! The other hose is used to actuate the turbo waste gate. If the waste gate doesn't actuate when necessary, you'll get a serious noise, and a burst of very rough performance. Is this the problem you're working on?
Old Jul 24, 2014 | 05:51 PM
nine5raptor's Avatar
nine5raptor
The vacuum pump is also used to activate the wastegate, so you will lose power brakes and wastegate actuation among other things I am sure. Do not drive the car with either disconnected as stated above.
Removing either is bad.
I broke my vacuum pump outlet (ecs stated to be careful in their post). I would agree. You cannot buy the outlet adaptor separately from the pump.
Sent from my Nexus using NAMotoring
Old Jul 28, 2014 | 08:52 PM
Gabe3's Avatar
Gabe3
I was diagnosing the rattle sound during startup. it did end up being the vacuum pump. the pump has a tsb for it and its "normal" for it to make that sound. where you actually hear the sound is on the valve cover. for me, it was the 2nd cylinder area from the passenger side.
Old Jul 29, 2014 | 06:27 AM
+1 on watching the removal of that upper line. The black nozzle part is a separate piece but can only be bought new with the whole vaccum pump. The vacuum pump linked above is for the N14 Engine ( Cooper S / JCW ) Turbo.
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Marco Guardado
Sep 15, 2015 01:22 AM
scottrn
Aug 22, 2015 07:26 PM
patrioticmini
Aug 20, 2015 10:54 AM
marendt428
Aug 8, 2015 04:44 AM
