R56 2009 Bonnet Cable Broke
Old Jun 5, 2014 | 05:21 PM
mkoutnik's Avatar
mkoutnik
How do I open the bonnet when the cable is broke? The lever in the car is useless...
Old Jun 5, 2014 | 05:34 PM
67morris's Avatar
67morris
Remove the panel where the latch is. You should be able to pull on the cable if the cable no seized. My got stuck a few months back and I had to use pliers. Once you get it opened, lubricate it good.
Old Jun 5, 2014 | 05:37 PM
danjreed's Avatar
danjreed
A quick search says to pull the panel off near where the release is (inside the car). See if its detached from the lever.
If not... looking at this pic..
You can't get at it from the front, but you might by taking out the drivers side fender liner panel.. and trying to access the cable where it splits into two cables.. (under the rad support, near the headlight.)
Old Jun 5, 2014 | 06:35 PM
mslatter's Avatar
mslatter
Most often, it's the pull, not the cable. It breaks all the time (according to the internet) and is just a matter of putting some pliers on the cable and pulling. Then buy a new release and install it (maybe $15.)
If it really is the cable, then get under the car. You've got two latches to release. Use a long bar or screwdriver, and come up underneath the latch, trying to push about where the cable attaches to it. I had luck pushing the cable itself up on one side, but had to catch a little tab on the other side. Upward pressure in just the right spot will release it. It took me about 10 minutes once I figured it out.
Old Jun 5, 2014 | 06:56 PM
mkoutnik's Avatar
mkoutnik
Thank you for the replies! I'll check to see if the pull is broke.
Old Jun 5, 2014 | 08:04 PM
luigi90210's Avatar
luigi90210
time for hood pins XD
Old Jun 6, 2014 | 04:23 PM
mslatter's Avatar
mslatter
Nah, you can't get to that from the wheel well. The coupling is in a little case that's pretty high up and you're access to it is pretty blocked on that side. You've got to open the latches themselves, which, really, isn't that hard. You've just gotta poke a bit, and be ready to get a dirty arm.
Old Jun 11, 2014 | 05:34 AM
Here is a thread where I talked about it and things to check.
https://www.northamericanmotoring.co...hood-help.html
09R56
Oct 12, 2015 09:04 PM
twriter
Oct 2, 2015 03:14 PM
minimofo
Sep 30, 2015 12:26 AM
DevilMeTaz
R60/R61 Stock Problems/Issues
Sep 22, 2015 05:19 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
