R50/53 Coil pack and wires.
Old Jun 4, 2014 | 06:10 AM
Mark97xp's Avatar
Mark97xp
So im looking to replace my coil and spark plug wires. Since i read bad reviews about MSD and others i figured i would just go OEM. Is it true that Prenco is the stock replacement?
Prenco 36-1158 (coil pack)
Prenco 35-pf77064 (plug wires)
Shopping around looks like you can get both for around $80 , Minimania wants $136 just for the coil
Old Jun 4, 2014 | 07:00 AM
minsanity's Avatar
minsanity
Prenco looks to be the OE for coil. Go Genuine for wires. They're reasonably priced. I compared the Beru leads, not exactly the same as genuine. Haven't seen the Prenco plug wires.
Old Jun 4, 2014 | 07:08 AM
bavmotors's Avatar
bavmotors
I'm running Ireland engineering wires, good wires at a reasonable price, look nice also. I agree, go oem with the coil pack.
Old Jun 4, 2014 | 07:09 AM
OVREZY's Avatar
OVREZY
I just purchased the Beru -- have used their plugs for years, have not installed yet. Cost was around $60.00 shipped from ECStuning
Old Jun 4, 2014 | 07:30 AM
joshamman's Avatar
joshamman
I have 2 stock coil packs, one removed from an R52 at 48k and one from an R53 at 52k miles. $40 for either if you want. No problems with either, just upgraded. PM me if interested.
I replaced mine with the MSD years ago and have never had any issues, its been tuned twice.
Old Jun 4, 2014 | 07:54 AM
Mark97xp's Avatar
Mark97xp
Thanks for the offer and no offense but i only have 42k on my 03 MCS that im looking to replace with new not used.
Old Jun 4, 2014 | 08:23 AM
ashchuckton's Avatar
ashchuckton
Can I ask why you are replacing a functioning coil pack? Wires I understand.
I have a coil pack on my car with far north of 100,000 miles & it is working fine.
Old Jun 4, 2014 | 08:47 AM
joshamman's Avatar
joshamman
No offense taken, I just thought I'd offer.
Old Jun 4, 2014 | 08:58 AM
Mark97xp's Avatar
Mark97xp
Functioning yes but 11 years old. Cant hurt to spend $40 to freshen her up.
Old Jun 4, 2014 | 09:23 AM
CoolioMcPimp's Avatar
CoolioMcPimp
I have to agree that OEM coils are a good idea. Wires are probably offer more choice, but OEM stuff is the safe idea.
Old Jun 4, 2014 | 09:44 AM
mini_gunner's Avatar
mini_gunner
What's the issue with adding more spark by upgrading coil packs and wires? I'm a mini noob but my previous experience with any combustion engine is it's never a bad thing to increase spark. Increase incoming air flow, fuel flow, combustion spark and exhaust flow.....right?
Old Jun 4, 2014 | 12:30 PM
bavmotors's Avatar
bavmotors
Aftermarket coil packs have been known to fry ecus.
Old Jun 4, 2014 | 02:11 PM
Mark97xp's Avatar
Mark97xp
Has anybody been able to confirm that Prenco is indeed the coil pack that Mini uses?
Old Jun 10, 2014 | 05:04 AM
CoolioMcPimp
Spark plug failures
Sometimes adding extra spark causes overheat / misfire / early detonation. Very similar to heat soak. I know this is plugs, but if the plug is getting too much spark you will also be likely to be melting plugs etc. Along with ecu not giving proper readings because of improper voltage from the coil.
I'm not a mechanic or anything, but I had a bad time with too hot of plugs in my Hyundai.
PsychoRallye
21
Feb 17, 2019 06:08 AM
vetsvette
Oct 20, 2015 07:42 AM
vetsvette
Oct 15, 2015 09:04 AM
simo711
Oct 1, 2015 05:36 AM
ericf1993
Sep 26, 2015 03:58 PM
