R58 Alta thermal blanket purchase (Pros & Cons)
Old Jun 2, 2014 | 06:40 AM
tilted's Avatar
tilted
I'm debating whether or not to pull the trigger on an alta blanket for my 2012 JCW coupe. There's one available local for $250, but I'm weighing the pros and cons.
I've had to replace oil feed lines on my previous mini to the tune of $1000 and I'm curious if the blanket would a) help prevent this problem b) cause any additional problems. I've heard keeping the heat in the turbo could cause the oil to build up within the turbo of the car as opposed to the feed lines.
Any thoughts?
Old Aug 30, 2014 | 01:42 PM
wzabrouski's Avatar
wzabrouski
Been thinking about the same thing.
Old Aug 31, 2014 | 05:58 PM
dube53's Avatar
dube53
What is the purpose of this accessory.............
Any thoughts?
I am curious. Is is for cold or desert driving conditions?
Old Aug 31, 2014 | 07:30 PM
DAVESTER's Avatar
DAVESTER
You can buy the insulation pad from the dealer for les than $100. Your oil feed lines should be insulated from the factory on your Coupe. Mine was. Your bonnet will be nice and cool with the pad installed and your stripes will not melt or discolor. There are no cons.
Old Aug 31, 2014 | 08:01 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The Alta removes the stock metal heat shield. I don't like this has the metal fits the best and works as designed. The blanket will then cause the heat to come around the edges and can damage the valve cover or anything else that can't handle the temps when you use it without the metal in place. We've seen these issues anytime someone removes the stock metal heat shield. That is why we designed our turbo wrap to only go on the hot side of the turbo and have your reinstall the stock metal heat shield to keep everything working as designed.
Check ours out as it is the original designed back in 2007 and much more affordable.
http://www.waymotorworks.com/wmw-turbo-heat-shield.html
Old Sep 1, 2014 | 01:15 PM
wzabrouski's Avatar
wzabrouski
Do you also recommend a heat shield like the NM or of the like?
Old Sep 1, 2014 | 02:54 PM
SeaSoldier's Avatar
SeaSoldier
Shouldn't need a heat shield after this. However I have one because I think it cleans up the space.
Old Sep 1, 2014 | 02:55 PM
DAVESTER's Avatar
DAVESTER
Don't know about a R60. I was speaking of a R58.
Old Sep 1, 2014 | 06:45 PM
CPap's Avatar
CPap
Just installed my alta turbo/mani blanket. I also wrapped the downpipe in lava wrap. I ended up removing the heat shields. Will report back after a few miles.
Attached Thumbnails Alta thermal blanket purchase (Pros & Cons)-image-405171227.jpg
Old Sep 2, 2014 | 10:11 AM
redparchel's Avatar
redparchel
just curious, what did you connect the bottom of the ALTA blanket to? since I believe it's supposed to screw into the lower heat shield and I wasn't sure how it would do w/o it
Old Sep 2, 2014 | 12:00 PM
NewCooperFanatic's Avatar
NewCooperFanatic
So that's what it looks like installed...been running Ways since after I broke the car in.
Old Sep 2, 2014 | 12:04 PM
CPap's Avatar
CPap
I used stainless straps and connected the rings (that are supposed to get the screws that connect to the OEM heat shield) on the bottom of the blanket together.
Old Sep 2, 2014 | 04:55 PM
wzabrouski's Avatar
wzabrouski
I see a meth line hiding...
Old Sep 2, 2014 | 05:55 PM
CPap's Avatar
CPap
Haha all for the sake of being cool. ;0)
Old Sep 2, 2014 | 06:15 PM
dube53's Avatar
dube53
How this modification affect the warranty on a new car if something goes wrong?
Do you really get more power from the R58 JCW engine?
I am just curious
Old Sep 2, 2014 | 06:24 PM
CPap's Avatar
CPap
Originally Posted by dube53
How this modification affect the warranty on a new car if something goes wrong? Do you really get more power from the R58 JCW engine? I am just curious .
I doubt a respectable dealer would give it a second look if something went awry. Then again, if something like your turbo went south, I would be sure to remove the blanket before making the visit.
You won't feel any difference in power. Things will will be cooler. Me? I was just itching to ditch those pesky heat shields being that I am always tinkering.
Old Sep 2, 2014 | 07:37 PM
WayMotorWorks
Vendor
Yes I like to use the NM heat shield as it fits the best and works great. It is what I run on my person car.
Old Sep 5, 2014 | 08:35 PM
NewCooperFanatic
It looks good, but isn't it having it over the oil line a bad move?
Old Sep 6, 2014 | 04:35 PM
CPap's Avatar
CPap
It doesn't cover the oil line. The oil line has it's own cover (similar to stock) ... let's the heat out and reflects the heat away.
Old Sep 6, 2014 | 08:07 PM
NewCooperFanatic
It's under there....looks covered to me.
My thought is just, why throw something on there that retains heat that much longer? My stripes don't fade, my scoop doesn't melt.
Pure aesthetics?
Old Sep 7, 2014 | 03:58 AM
CPap's Avatar
CPap
It's under there....looks covered to me. My thought is just, why throw something on there that retains heat that much longer? My stripes don't fade, my scoop doesn't melt. Pure aesthetics?
I didn't know you were referring to something other than the topic.
I do see your point with the nm heat shield though.
woodstudio
Mar 15, 2020 08:28 AM
jeremy_reyes94
Sep 6, 2019 07:53 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
smarsha11
Aug 24, 2015 06:03 AM
