R56 Massive code errors and limp mode
Old May 29, 2014 | 01:19 PM
Magicalhands's Avatar
Magicalhands
Hey all, first post and am in need of some serious help. I have an 09 cooper s. Bought it 2 weeks ago and haven't drive it much as I've been busy. Took it out for a cruise and got on it and threw me into limp mode. Usually happens at 3100 rpms in only 4th 5th and 6th. Went to a bmw performance shop and they ran these codes::
rt Test
DME MED for R56 Turbo
Current Fault Codes
2885:
DME: Charge-air pressure control deviation, plausibility
Error will not cause a warning light
Error is currently present
Test conditions have been completed
Signal or value below threshold
Dynamic stability control R56 (DSC TRW EBC450)
Current Fault Codes
5E5D:
Brake pad rear worn
Error will cause a warning light
Error is not currently present
5E30:
Control unit internal: System voltage excessive low
5E31:
Control unit internal: System voltage low
5E06:
Wheel speed sensor rear left missing
Test conditions have not been completed
Timeout
5E07:
Wheel speed sensor rear right missing
Timeout
5D90:
Excessive Wheel speed sensor invalid
D36A:
CAN message: F_CAN_CLU_1 ID:0x0D8
Timeout
D36B:
CAN message: F_CAN_CLU_2 ID:0x0E3
Timeout
D36C:
CAN message: F_CAN_CENTRAL LOGIC UNIT_STATUS ID:0x165
Timeout
Electronic power steering for R56
Current Fault Codes
610F:
CAN: Speed signal, ID 1A0h, invalid, not plausible
Short circuit or signal interruption
Airbags
Current Fault Codes
9408:
Supply voltage - low voltage in PDC
93D0:
Supply voltage - Voltage too low
93FB:
SBR - function - Velocity signal missing
Car Access System 3
Current Fault Codes
A10A:
EWS4 timing challenge/response error
Timeout
A0B5:
Signal identification peed error
Control panel IHS R56
Current Fault Codes
9C90:
IHS: Control-module fault
E72B:
IHS: No message (position EFH passenger's door)
E72C:
IHS: No message (position EFH driver's door)
E71C:
IHS: No message (road speed, 1A0)
9C75:
IHS: Undervoltage or overvoltage
Instrument cluster R56
Current Fault Codes
A3AC:
CAN ID 1A6 error: Stretch of way
931D:
On-board power, overvoltage or undervoltage
Light Control (Footwell module)
Current Fault Codes
9CB8:
Prevention battery deep discharge: switch off parking light
9CB5:
Battery deep discharched
9CC8:
Hall sensor power window passenger door defect
Timeout
A8AB:
Dipped headlight right defective
Timeout
A8B1:
Indicator front right defective
Timeout
9CB6:
LWR coil break
Timeout
A8AD:
Corner light right defective
Timeout
Computer / CCC (Application)
Digital terrestrial radio
Sunroof module
Current Fault Codes
A86D:
Lmao. So yeah that's what I'm dealing with. Any suggestions would help. I've tried a new battery and had the alternator checked. All fine. I seriously hope this happened to someone so I can just get the part and fix it , cause I do t have 2-4k so throw at a dealer find the problem. Thanks!!!!
Old May 29, 2014 | 01:24 PM
Magicalhands
Also it was in a minor left front collision. Said it wasn't bad.
Old May 29, 2014 | 01:34 PM
Fly'n Brick's Avatar
Fly'n Brick
First thought was battery, but...
Too many voltage errors in too many different locations to be as simple as a faulty switch, relay or sensor. If there was improper repair of any damage done to wiring from the collision there could be some very confusing signals that the ECU just can't unscramble. Modern computerized cars don't take practical jokes very gracefully.
Old May 29, 2014 | 01:44 PM
rckrzy1's Avatar
rckrzy1
start with a battery and go from there and or a loose ground wire.
Old May 29, 2014 | 02:03 PM
Magicalhands
Haha. No joke. So do you think this would be a some what cheap dealer fix. Or are they going to milk me for what I'm worth? The shop that I went to seemed pretty decent. I really don't know where to got from here lol.
Magicalhands
Changed the battery already.
Old May 29, 2014 | 02:07 PM
Magicalhands
I just don't get it. For me to be able to bring it up to redline (if I so pleased to do so) in first and second, but third is iffy. Sometimes I can take it to 4500 rpms but lately it seems to be consistent just over 3k rpms to go in limp mode. Just don't understand why first and second are fine.
Old May 29, 2014 | 02:39 PM
Bruce/Fl's Avatar
Bruce/Fl
Just trying to think outside the box here.
Your engine speeds vary in all the gears, you can run it up in 1st and 2nd but above that then you have issues. Well, 3K (or whatever) in 3rd the car is moving through the air a lot faster than 3K in 1st. Which led me to thinking maybe it is indeed a wiring issue, and the act of the car cutting through the air at a faster clip in the higher gears is adding vibration to a damaged/faulty harness or connector somewhere that is in a position to be impacted by the faster moving air.
Old May 29, 2014 | 03:08 PM
Systemlord's Avatar
Systemlord
Others may not have it in them to say it, this isn't going to be cheap! Why on earth do you think the guy sold it to begin with? Hint, hint... This is my case why buying from a reputable reseller (like CarMax) with an extended warranty plan to cover issues you're having is a good thing, the warranty might now be cheap ($2800), it's a lot less than you'll pay out of pocket! Electrical issues with Mini's is very troublesome, these Mini's are extremely sensitive. Electrical problems with any brand of car is sometimes worse than mechanical problems.
Hopefully this is a lesson not to buy a used Mini from a private party without a warranty, buying a used MCS with N14 engine is the worst used you could ever buy used as of right now! He even told me that he tried to communicate with the corporate office of CarMax to stop buying and selling Mini Coopers because it was ruining their reputation. CarMax corporate didn't agree because their making a **** load of money. If you think about it for a second, ask yourself if you were a successful vehicle reseller with what you know now would you continue selling Mini coopers that could quite possibly tarnish your reputation?
When I first drove my MCS off the CarMax lot they give you 5 days to return your car for a full refund if you're not happy with it. Who does that?
Old May 29, 2014 | 03:20 PM
cerenkov's Avatar
cerenkov
Most of those errors are even present (they are probably mostly old errors that should be cleared out)
I'd concentrate on the first one: the charge-air one, it is probably the one that is causing limp mode. Look for cracked or leaky boost tubes. Could be a MAF sensor.
Check this thread out:
https://www.northamericanmotoring.co...usibility.html
Old May 29, 2014 | 05:01 PM
scubbysnacks's Avatar
scubbysnacks
You've probably already done this but clear all codes drive it and see what codes you get and work from there will be a lot less confusing and you can focus on the current problem.
Old May 30, 2014 | 07:04 AM
Magicalhands
Yeah. He's having kinda the same issues as me but without the massive code readings. They have all been wiped and all comes back the same. Car boosts fine in 1&2. So I see no issues there. I'm stumped. I guess I'll have to wait til I have 5k to dump into it. Sigh
Old Jul 31, 2014 | 10:21 AM
cmacattack's Avatar
cmacattack
I just got that same code that threw my car into limp mode in the higher gears during spirited driving with twists and turns and uphill climbs. It just happened during the Mini Takes The States event while we were in Colorado headed towards New Mexico. Luckily Mini provides a Master Technician to help any cars that have problems. He found that there is oil in my intercooler that my regular mini tech did not find when replacing my failed turbo a few months back. The higher gears require more air and the spirited driving caused the oil to slosh around inside the intercooler and temporarily blocked the charge air for a split second causing the revs from the turbo and engine to not match and throwing the car into limp mode. He cleared the code and it's fine so long as i don't drive too hard. Unfortunately this caused me to have to back out of the MTTS event and head back to Utah to have it serviced.
Old Aug 1, 2014 | 12:06 PM
bmx045's Avatar
bmx045
it was in a collision? when?
carid
Dec 28, 2025 04:11 AM
thadscottmoore
Jun 4, 2021 07:19 AM
patsum
26
May 29, 2021 06:29 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
MasterShaftner
Sep 4, 2015 03:52 PM
