F55/F56 Fuse Box
Old May 17, 2014 | 12:36 PM
GregoryK's Avatar
GregoryK
Fuse Box
I'm a fiddler.
In my manual it states on page 199 that the fuses are under the glove box and you remove 2 screws and the fuse box folds down. THIS IS INCORRECT! If you undo the 2 screws you will remove an air bag!
You will need a flashlight. you can see some fuses against the firewall - they drop down when you push the tab on the left side left. (North American Model). There is a plastic pin on the right side and the whole thing (rather cheaply) falls down bring all the wiring with it. The fuse layout is on a piece of paper folded up and slotted into the "box".
To put it back you push the box up and to the right to insert the pin and slot back the left side - it will snap in place. This system holds the box in the correct position and there is no need to worry about the top of the box.
Here are some pics...
Attached Thumbnails Fuse Box-dsc02233.jpg   Fuse Box-dsc02232.jpg   Fuse Box-dsc02230.jpg
Old May 17, 2014 | 12:37 PM
GregoryK's Avatar
GregoryK
Other side of the fuse layout....
Old May 17, 2014 | 02:04 PM
R99's Avatar
R99
Were you looking for the fuse relating to the noise generator by any chance?! ha
Old May 17, 2014 | 02:22 PM
GregoryK's Avatar
GregoryK
R99...you guessed! One thing for sure I only have the fuses shown and I can not see the noise generator one. Need a wiring diagram for that.
Interesting how the fuse diagram shows you which side of the car the fuse box is on even though you have to take the box out to find the piece of paper with the info printed on it! "Just to be perfectly clear just incase you forgot..."
Old May 17, 2014 | 02:35 PM
rkw's Avatar
rkw
An alternative is to unplug the Active Sound module, if you can find it at the left rear: http://www.motoringfile.com/2014/03/...-engine-noise/
The TIS site has MINI wiring diagrams, but you'll have to spend $30 to find out whether it's been updated for the F56: https://www.minitis.com/
Old May 17, 2014 | 02:39 PM
GregoryK's Avatar
GregoryK
rkw - thanks. Not ready to pull the entire car apart today. I'm sure there is a fuse and it not I'll disconnect it when I upgrade the speaker and amp. :-) (can't wait!)
Old May 17, 2014 | 02:51 PM
rkw's Avatar
rkw
There should be an access panel in that area, for replacing tail light bulbs.
Old May 17, 2014 | 03:09 PM
GregoryK's Avatar
GregoryK
I thought it was in front of the drivers side rear wheel well?
Old May 17, 2014 | 03:28 PM
rkw's Avatar
rkw
The images are vague about the exact location. You'll have to check.
Seems like at least you might be able to see it:
Old May 17, 2014 | 04:02 PM
GregoryK's Avatar
GregoryK
rkw- thanks...I'll take a look
Old May 18, 2014 | 04:39 PM
champ198's Avatar
champ198
I guess if we upgrade the exhaust in the future, we need to know how to unplug the "your engine sounds cooler than it really is" fantasy box so it doesn't compete with it.
Let us know if you can tell a differnce when you disconnect. I have mixed feelings about fake engine sound being pumped into the cabin to make me feel better about the car.
Old May 18, 2014 | 05:42 PM
angrybears's Avatar
angrybears
Reading this, sounds like what ever sound they do pump in is pretty minimal. Would you even notice a difference after going through the effort of having it removed?
Old May 18, 2014 | 11:51 PM
rkw's Avatar
rkw
Here are sound clips comparing Active Sound on and off on a BMW M5: http://f10.m5post.com/forums/showthread.php?t=680384.
In the recording, Active Sound was disabled by pulling the fuse for the car's entire sound system. This is what I expected, that Active Sound would not have a separate, dedicated fuse.
Old May 25, 2014 | 08:03 AM
GregoryK's Avatar
GregoryK
RKW. OK just where you said. haven't unplugged it yet. What is interesting is the size of the plug that goes into it and the number of wires (must be 30+). Maybe this is not the right box but I'm unplugging it and will report back!
Old May 27, 2014 | 05:02 AM
GregoryK's Avatar
GregoryK
Should have figured that out. The box o n top of the left side wheel arch is the H/K amp.
I can not believe that they want over $900 to replace it! quite small....but you can tell the way it is mounted that they a fighting for space to put things in this car.
Will have to pull the trim to get to the noise generator.
Old May 27, 2014 | 06:19 AM
champ198's Avatar
champ198
Mine looks just like the one in the photo in this thread and just behind the small door. Has a big wiring harness.
Old May 27, 2014 | 06:27 AM
GregoryK's Avatar
GregoryK
Champ. Is it in the horizontal or vertical position?
Old May 27, 2014 | 08:50 AM
champ198's Avatar
champ198
I hope this pic comes through ok. It is a photo from the driver's side rear panel with the access door removed. It looks just like the image in this thread.
Old May 27, 2014 | 09:14 AM
rkw's Avatar
rkw
That photo must be of the HK amp, and it would be consistent with a connector having many wires.
http://realoem.com/bmw/partgrp.do?mo...86&hg=65&fg=25
Old May 27, 2014 | 09:54 AM
champ198's Avatar
champ198
rkw is correct. I snapped a couple more shots by sticking my phone further into the opening. It says Harmon Kardon on it.
Old May 27, 2014 | 10:33 AM
GregoryK's Avatar
GregoryK
and I unplugged mine and the radio, phone etc stopped working as I stated above.
Old May 27, 2014 | 10:49 AM
champ198's Avatar
champ198
So, this active sound box is like finding bigfoot?
Old May 27, 2014 | 03:36 PM
Pennengr's Avatar
Pennengr
Why would it not just be a chip on the head unit/amp? Seems like it would be the most cost-effective.
Old May 27, 2014 | 03:50 PM
GregoryK's Avatar
GregoryK
I'm not getting this. The amp is only in the HK system according to REALOEM. So the if you have a base stereo with sport mode then where does the sound come from.
I'm sure it has to be a hidden separate box.
IMO Greg
Old May 27, 2014 | 03:56 PM
Pennengr's Avatar
Pennengr
IMO Greg
Maybe so. Happy hunting.
Hobine
Oct 7, 2015 04:52 PM
eliseo1981
Sep 30, 2015 01:53 PM
asmasm
Sep 21, 2015 08:23 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
Puggles
Sep 11, 2015 11:53 AM
