R56 Bolts for front brake carrier?
Old May 14, 2014 | 09:33 PM
marantz2010's Avatar
marantz2010
After hunting for the issue, turns out one of the bolts for my R56 front brakes was not just loose, but entirely fell out today. (The worse nails on a chalkboard anybody could ever hear) It was one of the bolts that holds the carrier to the rest of the car. See one of the bolts from part #4: http://new.minimania.com/part/G2NMB4...8-59-Cooper--S
Would anybody be able to point me in the direction of where I could pick up just the bolt and not the entire assembly? Would the dealership carry just the bolt, or would I be able to find a bolt like this at Lowe's or Home Depot? I'm having a he11 of a time trying to find even what this bolt is called or the specs for it.
Thank you in advance!
Old May 14, 2014 | 10:03 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Look up the part number on realoem.com, then go to ECStuning.com and do a search for that part number. Click add to cart, etc...
or go to your local dealer with the part number.
Old May 14, 2014 | 10:20 PM
marantz2010
http://realoem.com/bmw/showparts.do?...23&hg=34&fg=05
I'm seeing the bolt I need, but it's not clearly labelled: #2 bolt unlabeled (not the #5 bolt)
Old May 14, 2014 | 10:31 PM
cerenkov's Avatar
cerenkov
There is no #2 bolt. Are you sure it's not #5. That would be a M12x1.5x32
EDIT: It definitely #5, same bolt in your first link to mini mania.
Old May 15, 2014 | 05:46 AM
Yea, looks like you need number 5 : Compare it to the one you are replacing. Part # 34116772428 size: M12x1.5x32
http://www.ecstuning.com/Search/SiteSearch/34116772428/ES2676317/
Old May 28, 2014 | 04:32 AM
marantz2010
Indeed it was #5! Thanks!
Old May 28, 2014 | 06:10 AM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
According to the manual, those bolts are supposed to be replaced when removed (yeah, right). The dealer should have them in stock. They are also supposed to have loctite on them. I just did my brakes this weekend and there wasn't loctite on the bolts (front or rear). Make sure you use some when you replace the bolt (81 ft/lbs on the bolt).
Old May 28, 2014 | 07:01 AM
JAB 67's Avatar
JAB 67
No way are those bolts routinely replaced. I needed a set for my brake upgrade kit (poor man's JCW) and neither local dealer had them in stock.
Old May 28, 2014 | 08:08 AM
scott13's Avatar
scott13
I reused mine too. Just brushed them clean and put a drop of Loctite on the threads and set them aside to dry while I worked on replacing the rotors.
Old May 28, 2014 | 01:05 PM
marantz2010
Does anybody know about the other set of bolts (the ones that hold the caliper to the carrier) in terms of using Loctite & torque rating? Perhaps the issue I am having is when I replaced the brakes, I wasn't following these guidelines. (seriously, I figured that if I torqued it as hard as I could with my fat socket wrench, all would be fine)
Old May 28, 2014 | 01:21 PM
run26385's Avatar
run26385
So what happens if you reuse bolts w/o loctite ? What is the likelihood of an unhappy ending ?
Old May 28, 2014 | 01:57 PM
Capt_bj's Avatar
Capt_bj
I never used loctite on mine, just t'q'd to the proper spec using the same bolts
I've done front rotors for myself and several others and nothing has fallen off yet.
but I AM talking GEN1 cars here and the questions above have bounced between GEN by posts . . . OP says the problem is on R56 but sig line says he has 2004 S aka R53 . . . bolts are NOT the same
Haynes for GEN1 says nothing about not reusing the bolts or L'T on anything . . .
if you do use Loctite be sure you use BLUE and not RED
RED generally requires HEAT to get it to break loose when you need to remove the fastener . . .
Old May 28, 2014 | 03:08 PM
jared_g91's Avatar
jared_g91
I had my brakes changed a couple of months ago and had the same thing happen to me. Although the shop I went to did a terrible job, so much so that I had to talk to the manager and get a full refund. They put rotors on wrong, damned caliper boot, damaged wheel hub, and also put pads on the wrong side (inside pads were on outside on all 4 wheels). But I was driving around and heard a weird scraping noise by the wheel. When I looked the caliper was sliding forward because the top bolt fell out. I'm joy sure it was because they did a terrible job or because they used the same bolts without any loctite. I just went to the dealer and the gave me 4 new bolts with loctite already on for free! They said they could put them on for free but couldn't because of liability issues. They did tell me that they replace them every time they change out the brake pads.
Old May 28, 2014 | 04:02 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
There was loctite on those bolts when I removed them and the manual says to use it as well. 35 ft/lbs.
Old May 28, 2014 | 04:08 PM
Capt_bj's Avatar
Capt_bj
the manual
WHAT MANUAL?
Old May 28, 2014 | 08:09 PM
marantz2010
This is very good info. (And yes, I have a R53 w/ "poor man's JCW brakes")
Learning lesson for all of us:
-Use loctite on all 4 bolts for each brake caliper
-Torque to specs and don't trust your "arm torque wrench" for something so important.
Thanks all!
Old May 28, 2014 | 08:49 PM
scott13's Avatar
scott13
Yes, I decided that if I was going to work on my MINI that I needed the proper tools including torque wrenches to make sure that bolts were tightened correctly.
Old May 28, 2014 | 09:44 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Originally Posted by Capt_bj
the manual
WHAT MANUAL?
squawSkiBum
Oct 2, 2015 09:21 AM
FLYM1N1
Aug 15, 2015 11:20 AM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
