R56 Head removal questions
Old May 10, 2014 | 01:34 PM
DocRob's Avatar
DocRob
Some of you may have read the thread where my friend's R56 needs the head pulled. I'm 95% of the way there, but have run into a couple snags.
How do I remove this sensor (CPS I believe)? I've removed the bolt, but it just twists a few degrees and I can't seem to pull it out. I need it out to gain access to the torx headbolt next to it.
Secondly, do I need to remove the units attached to the end of the cams shown by red arrows in the picture below? I assume it's part of the VANOS system, but didn't see any instructions to remove it in the VANOS removal section of the Bentley manual. That said, I feel like I probably need to remove it to take the head to a machine shop. If so, any idea where in the Bentley manual to find the procedure?
Last couple questions.
Does this kit include everything I need to replace when reinstalling the head? I doubt it includes the banjo bolts and gaskets for the turbo, etc. I'd love it if there was a list of items I need to purchase to replace.
http://www.minimotors.com/Classic_Mi...FZRcfgodnkEAHg
Lastly, anyone have a good source for a refurbished head? Just to save time rather than sending this one to a machine shop. Pretty sure one or more of the exhaust valves in cylinder one need to be replaced.
Old May 10, 2014 | 04:55 PM
oldbrokenwind's Avatar
oldbrokenwind
Originally Posted by DocRob
Some of you may have read the thread where my friend's R56 needs the head pulled. I'm 95% of the way there, but have run into a couple snags. Just finished putting mine back together. As I remember ---
How do I remove this sensor (CPS I believe)? I've removed the bolt, but it just twists a few degrees and I can't seem to pull it out. I need it out to gain access to the torx headbolt next to it. There's an o-ring to keep oil from leaking. Try pulling it straight out.
Secondly, do I need to remove the units attached to the end of the cams shown by red arrows in the picture below? I assume it's part of the VANOS system, but didn't see any instructions to remove it in the VANOS removal section of the Bentley manual. That said, I feel like I probably need to remove it to take the head to a machine shop. If so, any idea where in the Bentley manual to find the procedure? These units are pretty straight forward for removal / installation. I personally wouldn't trust a machine shop with a fully assembled head. I stripped mine down completely (except valves and springs) before sending it out. Also had to get another special tool to re-install the DI system. Between the Bentley manual, the web site "RealOEM.com", and "mechanical know-how", this chore can be done by a novice with little Mini experience.
Does this kit include everything I need to replace when reinstalling the head? I doubt it includes the banjo bolts and gaskets for the turbo, etc. I'd love it if there was a list of items I need to purchase to replace. This kit is way overpriced, and doesn't have nearly all the parts req'd. Cam gear bolts,, HPFP-to-DI rail pipe, exhaust manifold gasket, to name a few. I bought the head bolts, gasket, and cylinder head gasket set (which includes turbo gaskets and banjo washers, not the banjo bolts) from a dealer for about $390.
Lastly, anyone have a good source for a refurbished head? Just to save time rather than sending this one to a machine shop. Pretty sure one or more of the exhaust valves in cylinder one need to be replaced. Already sold my used head, to a guy for a hi-performance upgrade. Suggest you find a machine shop that can get replacement parts BEFORE taking it in.
The DI system should be re-installed before any other assembly work is done. A dealer has the tools and needs the head and DI injectors to do the work. Talk to the SA BEFORE starting the re-assembly, unless you have the specified tools. Best of luck ---
Old May 11, 2014 | 10:45 PM
DocRob's Avatar
DocRob
Thank you for the reply.
What is the DI system? I didn't even see anything in the Bentley regarding having to remove the injectors or fuel rail. I understand they are high pressure injectors, which I haven't dealt with before. Can you give me a little more info on what I need to do regarding this or what to search?
One other thing... after removing the VANOS gears I allowed the timing chain to settle in the cavity. I've then read somewhere on here to "not drop the chain". Is this an issue? I just assumed once I pull the chain back up it will hook itself back onto the crankshaft sprockets, no?
Old May 12, 2014 | 08:27 AM
afadeev's Avatar
afadeev
FWIW, I just did an N14 engine block swap (long story) that included transferring all the accessories from old to new block. DI injectors and fuel rail included.
There is some mention in Bentley about removing injectors and recommendation to replace all the gaskets. Removal procedure is simple and intuitive: unplug the injectors from the harness, unbolt the rail, pull both out. Supposedly, some may stick causing grief, but all 4 of mine came out together with the rail.
The gaskets' kit is expensive (~$60 * 4) and I didn't have it on hand when I re-installed the injectors with the 56K mile old seals. I also reused the old HPFP-to-DI rail pipe. Everything ran without any leaks afterwards.
No comment on VANOS, but I will taking apart the old block the next weekend and don't mind messing it up (it will go back as core). Feel free to request any experiments, if it would help with your job.
YMMV,
a
Old May 12, 2014 | 12:45 PM
oldbrokenwind
DI = Direct Injection --- another form of Fuel Injection. Bentley has a couple pages on removal / installation. Again, talk to the machine shop you plan to use. See if they want the head stripped of all attachments. Mine went to Thumper, and he said strip it. You can always remove only what's necessary, just to get the head off. If machine shop work isn't req'd, but it back together without removing everything.
Another hint --- I found the fuel line from tank to HPFP was not easy to disconnect, another special tool, so I removed the HPFP and put it in a Zip-lok bag, taped closed to minimize dirt. It kept nicely out of the way during head / engine removal.
Afadeev is correct about kit pricing. His choice to re-use gaskets / seals / and other Bentley-suggested replacement parts, is risky. I chose to replace them. The injector seal kits are also included in the previously mentioned gasket set, a much better price than individual gaskets.
I wouldn't worry about the timing chain. I let mine fall between the guides, just to keep it out of the way. There is solid material directly under the chain, so it should be easy enough to re-engage it, if needed. Once the head is off, the crank can be turned manually while engaging the chain.
One last item --- I'm working on my 1st Mini. Also my 1st experience with FI, turbos, & FWD. I bought the car used, about 3 ½ years ago, to mod. Any info from me is from experience on my car. Here's a link to my build journal, which was updated this week. https://www.northamericanmotoring.co...a-stuff-2.html
Old May 12, 2014 | 09:26 PM
DocRob's Avatar
DocRob
Pulled it off today. One exhaust valve in cylinder 1 is missing a chunk of metal, found the problem! I'm located in Los Angeles, and will probably be taking it to a place called Portflow tomorrow. The fuel rail is still in place, really hoping the work can be done with it on, but we'll see.
Likely will simply have them replace the valve, do any standard pressure testing, and maybe replace the valve seals. We'll see what they recommend.
That's what we did. Currently just have it hanging out in the engine bay, I see no reason why I need to bother dealing with that connector.
Will definitely be replacing all o-rings/gaskets/seals. You really think the dealer is the best place for buying these items? I always used pelican parts or rmeuropean for my M3.
That's what I thought, thanks.
Thanks for the link!
Old May 12, 2014 | 09:38 PM
DocRob's Avatar
DocRob
Some pictures:
Are the coolant passages supposed to be this color?
In all it's glory:
Carbon coated pistons (haven't checked the cylinder walls yet), some coolant leaked onto them:
And finally, the source of 0 compression:
Old May 12, 2014 | 11:48 PM
MNIPWR's Avatar
MNIPWR
I hear you are looking for an extra head? Ill have one in a week or so if you are interested.
Old May 13, 2014 | 12:21 AM
Systemlord's Avatar
Systemlord
Why do Mini's always have a piece of the valve broken in the same spots nearest to the plug?
Old May 13, 2014 | 03:04 AM
scubbysnacks's Avatar
scubbysnacks
ttp://www.bmminiparts.com/Home.aspx
I've found their prices reasonable especially compared to the stealers and their shipping cost is very good also.
Old May 13, 2014 | 07:46 AM
DocRob's Avatar
DocRob
Thanks, but I think we are going to rebuild this one.
Old May 13, 2014 | 07:47 AM
DocRob's Avatar
DocRob
Thanks for the link.
Old May 13, 2014 | 07:49 AM
DocRob's Avatar
DocRob
If this is truly the case it would likely because the cylinder gas flow on every mini is going to be nearly identical, so if the electrode of the spark plug is the cause, and assuming it breaks during ignition, it will probably travel to a similar place each time.
Old May 13, 2014 | 10:43 AM
oldbrokenwind
I chose the dealer for parts mainly because I'm not aware of any other LOCAL sources. Dealer parts pricing is a huge variable, and I'm a good enough customer so I'm getting a "better" price. I'm leary of online sources unless there's no other option --- "a personal problem". I don't remember the color of my coolant passage.
There's no good reason to not use the parts source of your choice.
Old May 13, 2014 | 01:23 PM
afadeev's Avatar
afadeev
Dealer is just a reseller, with mark-up.
Various dealers mark-up by various amounts, from 10% to 100+%. Thus it pays to call around.
The few times I had to comparison shop, Sewell MINI in TX was the cheapest by far: http://mini.sewellparts.com/
Buying out of state means you pay for shipping, but save on sales taxes. Depending on what exactly you are buying on how bulky it is, it is usually a wash after around $200.
Some parts come from BMW supply chain, some from Worldpac. The latter category are usually generic OEM items (bolts, hoses, filters, suspension components, etc).
For the latter category, someone on Amazon usually has the best price.
YMMV,
a
Old May 13, 2014 | 09:21 PM
thefarside's Avatar
thefarside
Interior of the head should be bright metal. Your head cooling passages look like they were exposed to very hard tap water - for a long time. There is evidence of rust in the block cooling passage as well. Remove the water in the bores ASAP! I expect the head will need to be pickled in some mild acid to remove what appears to be calcium stain.
Some pictures:
In all it's glory:
Old May 14, 2014 | 08:51 AM
DocRob's Avatar
DocRob
Don't worry, water is removed. It's not my car, I'll have to ask my friend if he was using regular water instead of distilled...
bobbiemartin
Jan 20, 2016 05:28 PM
silence2-38554
Nov 12, 2015 09:39 AM
Getrieben
Aug 15, 2015 09:09 PM
wind715
Aug 11, 2015 07:56 AM
MIminiclubman
Aug 5, 2015 09:14 PM
