Cooper (non S) Modifications specific to the MINI Cooper (R56).
Installed ECS's new coversion wiper blades
Old Apr 10, 2014 | 01:53 PM
Ive's Mini's Avatar
Ive's Mini
I installed the new conversion wiper blades and wiper arms that ECS sells that allow 2013 wipers to be installed on earlier R56s. They are great.
Attached Thumbnails Installed ECS's new coversion wiper blades-image-1061710056.jpg   Installed ECS's new coversion wiper blades-image-1981599023.jpg
Old Apr 11, 2014 | 05:30 AM
Very nice, looks great. Encase anyone is also looks for the conversion kit , its right here.
Aero Wiper Blade Conversion Kit Part # 61610039343KT
http://www.ecstuning.com/Search/SiteSearch/61610039343KT/
Old Sep 6, 2014 | 07:01 AM
DOC4444's Avatar
DOC4444
I have a 2010. What are the advantages of the 2013 wipers?
DOC
Old Sep 6, 2014 | 07:59 AM
Ive's Mini's Avatar
Ive's Mini
They area more even contact but it is more if an style thing. They are a simpler look.
Old Sep 6, 2014 | 08:12 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
For R53
Subscribed....
Been looking at their kit for the R53 too.....interested.
Old Dec 4, 2014 | 01:31 PM
kyoo's Avatar
kyoo
pics? i went from an '08 mini to a '13 mini, don't really recall anything about the wipers
Old Dec 4, 2014 | 03:21 PM
Ive's Mini's Avatar
Ive's Mini
They are a simpler architecture. Look at the first post and you'll see the initial pics. The original blade are conventional in design where these are spring steel.
Old Dec 5, 2014 | 05:55 AM
Yes pics are right above in the thread.
Old Dec 10, 2014 | 08:27 AM
nekky's Avatar
nekky
Is a wiper arm puller really necessary for this job?
Old Dec 10, 2014 | 08:31 AM
It makes thing easier and pull it straight up so you don't damage the splines on the wiper and motor arm side. If you have a Gen 1 MINI that never had them off , they tend to stick a little. Then when you reinstall just line up to the old potion.
DIY.
https://www.northamericanmotoring.co...onversion.html
Puller tool: Can be used on MINI and many other car brands, Currently on sale.
Easy to remove you old ones with the Schwaben Wiper Arm Tool. ES2190252
http://www.ecstuning.com/Search/SiteSearch/ES2190252/ES2190252/
Old Dec 10, 2014 | 06:38 PM
Ive's Mini's Avatar
Ive's Mini
If you lift the wiper arm so it is in a L shape, you can slightly rock it and it will usually release the taper. Don't apply too much pressure, just rock it and it should loosen up without a puller.
Old Dec 19, 2014 | 12:35 PM
You can rock it out, just watch the thread, so you dont chew them up. The tool makes sure that does not happen , also if they stick shoot a little pb blaster on the top.
Old Dec 19, 2014 | 12:40 PM
TVPostSound's Avatar
TVPostSound
The picture doesn't show that you really should put a towel under the wiper and tool, cause it will pop when released, and fall on your hood!!
DIY.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 7, 2015 05:56 AM
