Installed ECS's new coversion wiper blades
2 Attachment(s)
I installed the new conversion wiper blades and wiper arms that ECS sells that allow 2013 wipers to be installed on earlier R56s. They are great.
Very nice, looks great. :thumbsup: Encase anyone is also looks for the conversion kit , its right here.
Aero Wiper Blade Conversion Kit Part # 61610039343KT http://www.ecstuning.com/Search/SiteSearch/61610039343KT/ http://c1552172.r72.cf0.rackcdn.com/439946_x600.jpg http://c1552172.r72.cf0.rackcdn.com/412309_x600.jpg http://c1552172.r72.cf0.rackcdn.com/412320_x600.jpg Thanks |
I have a 2010. What are the advantages of the 2013 wipers?
DOC |
They area more even contact but it is more if an style thing. They are a simpler look.
For R53
Subscribed....
Been looking at their kit for the R53 too.....interested. |
Originally Posted by Ive's Mini
(Post 3985239)
They are a simpler architecture. Look at the first post and you'll see the initial pics. The original blade are conventional in design where these are spring steel.
Yes pics are right above in the thread. :)
Is a wiper arm puller really necessary for this job?
It makes thing easier and pull it straight up so you don't damage the splines on the wiper and motor arm side. If you have a Gen 1 MINI that never had them off , they tend to stick a little. Then when you reinstall just line up to the old potion.
DIY. https://www.northamericanmotoring.co...onversion.html Puller tool: Can be used on MINI and many other car brands, Currently on sale. Easy to remove you old ones with the Schwaben Wiper Arm Tool. ES2190252 http://www.ecstuning.com/Search/SiteSearch/ES2190252/ES2190252/ http://c1552172.r72.cf0.rackcdn.com/188503_x600.jpg http://c1552172.r72.cf0.rackcdn.com/412313_x600.jpg http://c1552172.r72.cf0.rackcdn.com/412315_x600.jpg Thanks |
If you lift the wiper arm so it is in a L shape, you can slightly rock it and it will usually release the taper. Don't apply too much pressure, just rock it and it should loosen up without a puller.
You can rock it out, just watch the thread, so you dont chew them up. :) The tool makes sure that does not happen , also if they stick shoot a little pb blaster on the top.
The picture doesn't show that you really should put a towel under the wiper and tool, cause it will pop when released, and fall on your hood!!:eek:
(Post 4021895)
| All times are GMT -7. The time now is 12:42 PM. |
