R56 Warped rear bumper--anyone else have this?
Old Mar 19, 2014 | 11:47 AM
Cngizbleevng's Avatar
Cngizbleevng
Looking down on the bumper in the rear, it's pretty obvious.
I can push the bumper in and even it out, but it bounces right back to its warped shape when I let go...
2010 MCS.
Old Mar 19, 2014 | 12:59 PM
Ex Z3Coupe's Avatar
Ex Z3Coupe
Do you parallel park ?Any scuffs ? It looks like you have been "tap't"
Old Mar 19, 2014 | 05:13 PM
Cngizbleevng
I just got the car last week, so I don't know about its prior history. I don't see any scuffs. I was thinking the exhaust heat might have caused it to warp.
Old Mar 20, 2014 | 08:57 AM
u238's Avatar
u238
Under the car you will see some flimsy metal brackets. Bend those to move the bumper back in the right place. It took me about 30 seconds.
Old Mar 20, 2014 | 09:26 AM
Cngizbleevng
That's interesting--thanks for the tip!
Old Mar 20, 2014 | 10:53 AM
Yea there is a bracket under there Right by number 10 and 11 in the diagram. Might be bent.
Old Mar 20, 2014 | 11:09 AM
cranker625's Avatar
cranker625
I doubt exhaust heat would warp the rear bumper, only on one side, about 6 inches away from the muffler.
Unless your car was stationary, running at 5000rpm, in death valley
Its most definite that your car got a little kiss in the rear.
The plastic wouldn't show any scuffs or marks, but the metal frame underneath would be bent.
And since the MCS plastics are somewhat thin in the rear valance area, it can be fixed by pulling the metal frame/bracket back in place.
Old Mar 20, 2014 | 12:58 PM
Cngizbleevng
You guys are awesome. Thanks for taking the time to clear things up!
Old Mar 20, 2014 | 01:19 PM
Welcome.
Old Mar 22, 2014 | 04:39 PM
Cngizbleevng
So if anyone else has this problem, here's what I did...
There is a fairly flimsy metal L-bracket behind the bumper on the passenger side only. That apparently had been lightly hit and bent inward (as ECSTuning suspected). It's very easy to see with the rear of the car backed up onto ramps. It is also easily bent rearward by hand, which I did. That pushed the bumper rearward on the passenger side which helped somewhat.
The problem then was that the driver's side of the bumper was still further rearward than the passenger side. To pull that side of the bumper inward, I clipped a metal clothes hanger to the appropriate length and hooked one end around the muffler 'hanger' and the other end hooked into the inside of the bumper.
Very easy fix and now the bumper looks perfect.
Old Mar 22, 2014 | 10:36 PM
Porthos's Avatar
Porthos
Dafaq? I would claim comprehensive on your insurance. That almost looks like you were hit.
Old Mar 23, 2014 | 05:52 AM
s0n1c's Avatar
s0n1c
I'm not sure I would do that...depending on your insurance company and such, that could make your rates go up. Plus the actual repairs may be cheaper than your deductible.
Old Mar 23, 2014 | 06:41 AM
Cngizbleevng
The repair cost me less than $1. Part of a metal clothes hanger.
Old Mar 23, 2014 | 06:44 AM
Cngizbleevng
The bumper is very thin plastic in that area. The car was probably lightly kissed by another car at one point, which bent the thin metal bracket behind the bumper. It was left that way for a while which resulted in the bumper wanting to stay in that warped shape. The fix was very easy.
emulajavi
Dec 24, 2018 09:15 AM
silence2-38554
Aug 29, 2015 08:10 AM
Mini'mon
Aug 26, 2015 01:02 PM
ShadyCoop
Aug 24, 2015 06:05 AM
