R56 My SA suggested adding Techron...
Old Mar 14, 2014 | 02:20 PM
Cngizbleevng's Avatar
Cngizbleevng
...fuel additive to our fuel at about every fourth fill-up. Is this standard, and how many of you do this?
Old Mar 14, 2014 | 02:27 PM
MikewithaMini's Avatar
MikewithaMini
Go to any car parts store or car accessory section of the department store and pick up a can. Other brands may be preferable over Techron, some more expensive. Get yourself a funnel as well so you don't slosh down the side of the car trying to pour it in the tank. I prefer to put additives in when I need a fill up, I put it in the tank at the station just before pumping the gas so it mixes well.
Old Mar 14, 2014 | 02:37 PM
ZippyNH's Avatar
ZippyNH
On a gen1 or on a Cooper (non-s) it can help clean stuff up...
But on a direct injected gen 2 s, it can only clean the injectors....
Think every 4th fill up is excessive and $$.
Old Mar 14, 2014 | 03:59 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
+1. AND the Techron formula has changed in recent years and isn't near as good as it used to be.
Old Mar 14, 2014 | 06:03 PM
Cngizbleevng
Any idea why they would have changed it?
Old Mar 14, 2014 | 06:40 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
No, however they reduced the amount of the ingredient that did all the cleaning (sorry I don't remember the chemical name). Maybe it was bad for catalytic converters or something.
Old Mar 14, 2014 | 06:56 PM
mbwicz's Avatar
mbwicz
Running a can of something (Techron or other brands) every once in a while cannot hurt, except for the expense. Personally, I put a can of Techron in every 5k miles when I change the oil.
Have fun,
Mike
Old Mar 14, 2014 | 07:03 PM
cerenkov's Avatar
cerenkov
Or you can just use "top tier" gasoline.
http://www.toptiergas.com
Old Mar 14, 2014 | 07:43 PM
ashchuckton's Avatar
ashchuckton
Techron is a good fuel system cleaner. I've run it in all our cars for years. It will help keep fuel injectors clean in a direct injection engine. It is not going to clean carbon off the valves. For that you need walnuts.
Old Mar 14, 2014 | 09:31 PM
LarriB's Avatar
LarriB
My SA told me the same thing, and said to use Chevron over 76 or Mobil.
2010 MCSC Chili Red - 6-Speed, Sport and Convenience Packages, Conti DW, Black Star 17", Leatherette, Base Stereo :-(, Ipod/Bluetooth, NM Torque Bushing, Sport Antenna, Blackout (Grill and Taillight surrounds, Side Scuttles), Polk Audio Speakers, BSH Oil Can and Boost Tap, H-Sport 19mm Rear Sway Bar, DoS CAI v2, JIC Strut Brace, Helix FMIC, IC Muffler Delete, Added rear fogs and got them programmed, Cravenspeed Dipstick, Way X Brace, More Mods to come.*
Filmy
15
Jun 6, 2023 06:27 AM
rlp
Sep 11, 2015 03:28 PM
MiniSkoon
Sep 9, 2015 12:40 PM
Norton70
Sep 7, 2015 05:06 PM
