R56 My Flywheel - not good
Old Mar 11, 2014 | 06:16 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
The pressure plate looks the same. The car has 23K miles on it. I knew it needed a clutch (the rivets were starting to hit causing a little squeal when I started off), but I was surprised by the rest of the damage. Somebody really smoked this thing. Damn flywheel is a $600 item.
Old Mar 11, 2014 | 07:37 PM
pbedrosi's Avatar
pbedrosi
Looks really bad.
I just had my '10 MCS flywheel and pressure plate replaced under warranty at 43k, some minor cracking but mainly heat spots. Previous owner must have rode the clutch. I just paid for clutch part cost.
Sent from my iPad using NAMotoring
Attached Thumbnails My Flywheel - not good-image-3168435759.jpg   My Flywheel - not good-image-3486756659.jpg
Old Mar 11, 2014 | 07:45 PM
rckrzy1's Avatar
rckrzy1
IMO a poor design or material. I got 95K out of Trans Am with about 3 times the power and I never babied it.
Old Mar 13, 2014 | 08:44 AM
komet155's Avatar
komet155
Sorry to hear that. Pretty scary.
Is it a Cooper S or a "Justa" and how many miles were on it when you bought it if I may ask?
Old Mar 13, 2014 | 05:35 PM
zrickety's Avatar
zrickety
Great time to upgrade to a single-mass flywheel and stronger clutch.
Old Mar 14, 2014 | 11:28 AM
JcarrollWS6's Avatar
JcarrollWS6
Might as well do a minor upgrade. But keep drivability in mind!!!
Old Mar 14, 2014 | 01:07 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
And that kept me with the stock setup. Nice change though. The pedal is so easy to operate now. It was a mess before.
Old Mar 14, 2014 | 07:46 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've been seeing more failed so we actually stock the R56 Flywheels now.
Old Mar 14, 2014 | 09:39 PM
gerardt20's Avatar
gerardt20
May I present to you my clutch and pressure plate. Dint know how to change the clutch myself so i had someone with the correct stuff to do it. He did the clutch, replaced my intercooler, and tidied it up.Went to pick it up and it was weird. i would rev the engine and the re circulation valve was not audible. I have the sandwhich type adapter on it. ended up being a messed up relay in the relay box. just wanted to add some story to it. i also purcased the car with 50k in september. Also my guy was able to get the flywheel cut.
andrewjg1994
Jan 29, 2021 07:45 PM
Kimolaoha
Dec 5, 2020 09:32 PM
Sep 17, 2015 09:27 AM
Camaro108
Aug 25, 2015 02:44 PM
Aug 25, 2015 12:58 PM
