Auto gearbox help
Old Mar 9, 2014 | 03:59 PM
Reflexboy's Avatar
Reflexboy
Auto gearbox help
Hi guys, been lurking for a while and finally signed up to this great forum. I have a 2009 cooper clubman auto and have recently been experiencing a problem with the transmission.
When the car is in 'D' it intermittently flicks between 'D' and 'DS'. When it does this, it quite rightly drops down a gear, but as I haven't selected 'DS' this is pretty annoying. It happened all the time for a few days and then, for no apparent reason was fine for about a week and now it's started again. It's almost like it has a mind of its own switching between the two different gearbox modes. When it's in 'D' and not flicking about the transmission works fine.
I have searched the net and found a couple of owners posting about the same problem but there doesn't seem to be an explanation. Is there anyone else out there who has had a similar problem or any Mini technicians who can explain what's going on here? Many thanks in advance.
Old Mar 9, 2014 | 05:18 PM
speedbird_1's Avatar
speedbird_1
It sounds like a faulty sensor inside the gear stick housing, which engages manual shifting when in D and moving the stick to the left into D/S. I would try taking it apart and seeing if there might just be something loose or broken, because I don't see any separate parts on realOEM. It's just sold as one unit, which appears to be around £500
http://realoem.com/bmw/showparts.do?...48&hg=25&fg=20
Old Mar 9, 2014 | 08:45 PM
yesti's Avatar
yesti
Long shot but maybe a bad sport button? Does it ever say 'sport' when switching back and forth?
Old Mar 10, 2014 | 12:03 AM
Reflexboy's Avatar
Reflexboy
Hi. It doesn't have a Sport button as such. To go from auto to DS which is in effect the Sport and Manual mode you just push the shifter to the left. I was thinking something like that, but haven't a clue where to start looking
Old Mar 10, 2014 | 12:04 AM
Reflexboy's Avatar
Reflexboy
Ok thanks. Will take a look at the weekend
Old Mar 10, 2014 | 12:05 AM
Reflexboy's Avatar
Reflexboy
Old Mar 10, 2014 | 12:09 AM
yesti's Avatar
yesti
So there's no sport button on the gearshift boot area? Sorry, just assumed it was there.
Old Mar 10, 2014 | 03:42 AM
Reflexboy's Avatar
Reflexboy
No Sir. To put it in sport mode I simply push the shifter to the left. If I want I can then tap it up or down a gear like tiptronic
Doc Pain
Mar 10, 2021 04:50 AM
vulkandino
Oct 31, 2015 08:29 PM
cub4bearindiana
Oct 2, 2015 09:45 AM
Oct 1, 2015 12:13 PM
kevinlhr310
Sep 27, 2015 02:31 PM
