P2400 Help
Old Feb 25, 2014 | 07:02 PM
Spigot1999's Avatar
Spigot1999
P2400 Help
The other day I was replacing my thermostat housing for the second time. (It was done back in 2009.) It went pretty easy, 2 hours with beer. This morning I head to work and my Check Engine Light comes on. I happen to have a reader in my car at the time and it's throwing a P2400 code. As an easy try, I swung by the Stealership and got a gas cap. $22 later and I have a shinny new gas cap and still a P2400 CEL code. I cleared the code and the CEL goes out. As soon as I turn off the car and start it again, the CEL comes on and I've got a P2400 code.
I've searched this site and the internet, but can't find any real solutions for this. Anyone have any thoughts or experience with this?
Thanks in advance.
Old Mar 2, 2014 | 04:01 PM
Spigot1999's Avatar
Spigot1999
Anyone??
Old Mar 2, 2014 | 06:16 PM
CA94960's Avatar
CA94960
I found this:
P2400 - Evaporative Emission System Leak Detection Pump Control Circuit/Open
Old Mar 2, 2014 | 06:32 PM
Spigot1999's Avatar
Spigot1999
Originally Posted by CA94960
I found this:
I found that as well, but does that mean the pump is bad? I'm thinking it means the pump is running, and that is why the CEL is on. But I'm not sure why?
Old Mar 2, 2014 | 07:27 PM
Slave to Felines's Avatar
Slave to Felines
The evap system includes the gas cap. That's the first thing to check.
The "pump control circuit/open" makes me think of an open circuit--something being unplugged. So that's another thing to check for.
Old Mar 2, 2014 | 08:34 PM
Spigot1999's Avatar
Spigot1999
Thanks for the input! I replaced the gas cap first thing. It was an easy fix, but no luck. I'll check to see if anything's unplug first thing in the morning.
Old Mar 3, 2014 | 09:16 AM
Spigot1999's Avatar
Spigot1999
Nothing appears to be unplugged, but feels like a needle in a hay stack. I found a thread on a bummer forum that talks about bleed down from a bad injector causing this code. Any thoughts on that? Do our injectors go bad often? Does anyone know a test to check for a bad injector? Thanks for the continued help!!
Old Mar 3, 2014 | 02:49 PM
Slave to Felines
I can't see how an injector would affect the evaporative emissions control system.
In older cars, we had a charcoal filter in place to absorb gasoline fumes from the air that got into the tank as the gas emptied out of it. That filter vented into the intake for the engine, meaning any extra gas would just get burned up.
Nowadays, the system is more complex and works better at preventing evaporating fuel from getting out. The fuel system and such is sealed and air-tight, except for the air that gets in when you pump the fuel out. (And that is probably pretty strictly controlled as well!) There is a small pump that either pulls a slight vacuum on the system to make sure it is sealed, or puts a slightly pressure on the system, I don't know which. If the pressure changes from where the pump sets it, the system knows there is a leak.
It sounds like it has figured out that the pump isn't running at all.
Don't know where the pump is in our cars, though, nor exactly how it is controlled.
Old Mar 3, 2014 | 03:06 PM
Spigot1999's Avatar
Spigot1999
Thanks for the great info. I'll see if I can find it and trouble shoot it.
Old May 15, 2014 | 04:52 PM
bavmotors's Avatar
bavmotors
Did u ever solve this issue? i have the code now and theres alot of threads with no solutions. I have a leaky thermostat housing gasket and valve cover gasket, not sure if thats relevant.
Old Mar 21, 2015 | 05:55 AM
GP0256's Avatar
GP0256
Anyone have any input on this?
Old Mar 21, 2015 | 10:37 AM
bavmotors's Avatar
bavmotors
I had a bad wire to my pump.
Old Mar 21, 2015 | 01:38 PM
GP0256's Avatar
GP0256
Where was it bad? In the rear near the pump on the trailing arm like most others?
Old Mar 21, 2015 | 01:40 PM
bavmotors's Avatar
bavmotors
unfortunately I don't have the specifics the dealer did it for me, I changed the pump and the charcoal canister and finally the wire was the culprit.
Old Mar 21, 2015 | 08:03 PM
GP0256's Avatar
GP0256
I am going to fix mine tomorrow morning and take some detailed pictures for everyone
Old Feb 10, 2018 | 11:14 PM
Mod-Mini's Avatar
Mod-Mini
Bump - anyone else resolve this issue - if wire was bad, where was the wire bad?
Working on a 2010 R55 Clubman with N12 engine. Also throwing intermittent P0300 P0301-P0304 codes when cold.
blakeslee_a
May 21, 2018 10:01 AM
GP0256
May 18, 2015 03:15 PM
Tab32
Nov 29, 2014 08:20 AM
Tab32
Jan 16, 2014 05:38 AM
BoostAddict
May 5, 2011 03:41 AM
