question about OZ leggenda wheels
Old Feb 21, 2014 | 01:34 PM
rmssuckd's Avatar
rmssuckd
Hi all,
I just got new 17" OZ leggenda wheels and I realize it didn't come with wheel caps.
It's fine for me but if i don't put on wheel caps, I can see the rusty center part.
I try to buy the OZ center caps online but I don't know which one will fit.
Is there anyone can tell me which size of caps I should buy? And where I can get?
If this wheels has no center caps, what can I do to remove those rusty part?
Thanks for the help.
Old Feb 21, 2014 | 01:52 PM
jkapinos's Avatar
jkapinos
Mask the hub and paint with Eastwood rust encapsulator matte black.
Old Feb 21, 2014 | 01:54 PM
bjcarter2's Avatar
bjcarter2
Odd...I was just looking for center caps for my OZ Carnovas.
Several things I have learned:
*OZ Caps are priced like gold.
*There are knockoffs out there.
*If you have just one center cap, the part number is on the back. For instance, mine has M582. A 52mm/55mm cap.
You may check with Tire Rack to see what they have to offer too.
You can look here too ... http://www.centercapsdirect.com/
Good luck with the search. I think those were designed to be run without caps though.
Maybe consider a high-density foam plug that can be cut and trimmed to fit inside nice and snuggly.
Old Feb 21, 2014 | 03:08 PM
signcarver's Avatar
signcarver
Tire Rack says "center caps not available". They look beautiful on your car!
Old Feb 24, 2014 | 09:40 AM
Alex@tirerack's Avatar
Alex@tirerack
He's correct. There would be no clearance for a cap. Due to the thin opening, there is no where for a cap to hold on.
Old Feb 25, 2014 | 08:45 PM
Melangell's Avatar
Melangell
I had Way install one of his stud kits which came with open nuts. The threads would show rust to the point I finally had to replace then with closed nuts. If I had your wheels and had to deal with rust, I'd probably break down and break out the Rust-Oleum!
Old Feb 25, 2014 | 09:27 PM
rmssuckd's Avatar
rmssuckd
Thank you for all the opinions.
I will just try to sand out the rust then spray the Eastwood rust encapsulator matte black on it.
I will update the pic after I receive the rust encapsulator.
Old Mar 1, 2014 | 09:16 PM
rmssuckd's Avatar
rmssuckd
Thank you jkapinos..
I sand the rust part and spray with rust encapsulator today, here is what the wheels looks like now.
Old Mar 2, 2014 | 06:56 AM
jkapinos's Avatar
jkapinos
Your welcome. That paint, even sprayed over rust and left outside, should last a year or so.
Old Mar 2, 2014 | 02:57 PM
Roadki11's Avatar
Roadki11
Those look awesome. How much brake clearance do you have? Will they fit over JCW brakes?
G1HQ
Dec 7, 2015 02:23 PM
thebordella
Aug 31, 2015 01:37 PM
Mini'mon
Aug 16, 2015 04:15 PM
ki7hy
Aug 12, 2015 07:07 PM
nomar116
Aug 10, 2015 11:24 PM
