Drivetrain Front Tie Rod End Boots for R53
Old Feb 19, 2014 | 02:58 PM
Manny_cooper's Avatar
Manny_cooper
Does anybody know the dimensions of the tie rod end boots on an R53? One of my boots is busted and wanted to know somebody around here has ever replaced them....without replacing the entire assembly.
This is the part, not to be confused with the sway bar links:
http://www.partsgeek.com/gbproducts/...FQ_l7Aod1FoAEQ
Thanks!
Last edited by Manny_cooper; Feb 19, 2014 at 03:14 PM. Reason: Added reference part
Old Feb 20, 2014 | 09:43 AM
jamez's Avatar
jamez
I'm sorry, I can't help with regards to the dims.
But are you looking to replace the Tie Rod end or the boot? Your link sends to the left tie rod end.
Seeing as the tie rod is sold in pieces it sounds like you can just replace the parts as necessary (but I don't know if that's best practice or not).
Just in case others want to see the Tie Rod replacement procedure:
http://www.pelicanparts.com/techarti...eplacement.htm
Old Feb 20, 2014 | 10:47 AM
Here is a link to a thread talking about the tie rod end link and the problems/ solutions for replacing them , there is a split year in 5/2003 for the Gen1 MINIs .
Click on the links to the products , some products have mutiple brands / price options you can choose from.
Tie rod boots.
https://www.northamericanmotoring.co...-rod-ends.html
Tie rods:
https://www.northamericanmotoring.co...ll-joints.html
Thanks and hope that helps.
Old Feb 20, 2014 | 11:47 AM
Manny_cooper
I'm trying to replace the dust boot that connects the tie-rod end to the steering assembly.
I've circled in red what I'm talking about. The tie rod is not damaged and there is nothing wrong with it. The only thing that need to be replaced is the dust boot. I know autozone/napa/advanced sells universal fit dust boots, but I was wondering if somebody knew the dimensions so I can norrow it down and find something that fits. Plus everybody can benefit from this thread.
ECS Tuning,
If all else fails, I will probably end un buying the tie rod end... but I think it's worth the try.
Old Feb 20, 2014 | 12:03 PM
minibx's Avatar
minibx
Originally Posted by Manny_cooper
I'm trying to replace the dust boot that connects the tie-rod end to the steering assembly. I've circled in red what I'm talking about. The tie rod is not damaged and there is nothing wrong with it. The only thing that need to be replaced is the dust boot. I know autozone/napa/advanced sells universal fit dust boots, but I was wondering if somebody knew the dimensions so I can norrow it down and find something that fits. Plus everybody can benefit from this thread. ECS Tuning, If all else fails, I will probably end un buying the tie rod end... but I think it's worth the try.
I don't think that you can.....nothing is impossible but in your case you have to buy the whole part
Old Feb 20, 2014 | 12:15 PM
Manny_cooper
I'm pretty sure that the whole part does not have to be replaced (if the tie rod were bent, then I would replace it).
The boot has clips that hold it in place, meaning it can be replaced.
Thanks for you input anyways.
Old Feb 20, 2014 | 12:23 PM
Welcome,
Thought you were talking about the boot on the rack to tie rod.
Don't think you can get that tie rod end bushing rubber boot by itself , I know you cant on the OEM MINI side. . Also if that boot is cracked or leaking grease the bushing joint get exposed and will wear out, that's where you get play. I would check the bushing for play also.
Old Feb 20, 2014 | 12:29 PM
minibx's Avatar
minibx
No problem, like I said nothing is impossible but getting that particular part will be a pain but there is always a redneck way :-) good luck
Old Feb 20, 2014 | 12:32 PM
Manny_cooper
I've already checked it out and there is no play in that area. I would think that play would happen if the LCAs and the inner and outter ball joints are bad. (Which I already ordered and will be replacing soon). I'm not trying to go cheap, I'm trying to find a solution to this without having to take the whole thing apart.
This is an example of what I've found. (I know, it's from ebay.. just using it as an example)
http://www.ebay.com/itm/Sealey-Ball-Joint-Dust-Covers-Commercial-Vehicles-RJC02-/121238681184?pt=LH_DefaultDomain_0&hash=item1c3a637660
Old Feb 20, 2014 | 12:41 PM
minibx's Avatar
minibx
I'm with you I would like to take the whole thing off lol.
Old Feb 20, 2014 | 01:55 PM
Manny_cooper
Somebody can jump in and help me research. There is nothing but good gains from this. Pretty sure someone will have to change this some day too.
Old Mar 10, 2014 | 06:42 AM
Manny_cooper
http://www.ebay.com/itm/FORD-MASSEY-FERGUSON-TIE-ROD-DRAG-LINK-DUST-COVER-BOOT-1-3-8-x-1-x-1-2-/191096263459?pt=BI_Heavy_Equipment_Parts&hash=item2c7e399323
I found the correct replacements for our dust cover boots on the tie rod ends. If yours are done for, you can get these ones. Just did a complete overhaul (LCAs, Inner/outter ball-joints) on my suspension this weekend, and they fit perfectly! Hope it helps everybody. It's good when you do a little research, it saves you a lot of money.
Note: You'll have to re-use the clips (those clips don't go bad).
Old Mar 10, 2014 | 08:31 AM
minibx's Avatar
minibx
Video Link: http://www.ebay.com/itm/FORD-MASSEY-FERGUSON-TIE-ROD-DRAG-LINK-DUST-COVER-BOOT-1-3-8-x-1-x-1-2-/191096263459?pt=BI_Heavy_Equipment_Parts&hash=item 2c7e399323 I found the correct replacements for our dust cover boots on the tie rod ends. If yours are done for, you can get these ones. Just did a complete overhaul (LCAs, Inner/outter ball-joints) on my suspension this weekend, and they fit perfectly! Hope it helps everybody. It's good when you do a little research, it saves you a lot of money. Note: You'll have to re-use the clips (those clips don't go bad).
Great info, thanks I'm sure it will benefit lots Of members :-)
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
maestro39
Oct 27, 2015 02:38 PM
FLYM1N1
Aug 15, 2015 11:20 AM
