MINI5280 The Motoring Society of the Rocky Mountain Region. Visit the club site at www.mini5280.org and Event Calendar.
Fact or Fiction, Toothpaste.
Old Jan 16, 2014 | 07:41 PM
d0r33t0s's Avatar
d0r33t0s
Does toothpaste really get your headlights sparkly clean?
if so, is there a certain brand that's better or does any old kind work?
is there a toothpaste for dummies instruction set?
Old Jan 17, 2014 | 05:44 AM
yetti96's Avatar
yetti96
Basically it is like a less wet, wetsand. The kits you can buy remove the top layer of oxidation and do it with progressively finer and finer grit to remove all imperfections and leave a nice finish. I would just buy a proper kit and spend the $20. That's my plan at least.
Old Jan 17, 2014 | 06:03 AM
Helix13mini's Avatar
Helix13mini
That's pretty funny. I suppose it would work. Try using a cleaner wax with a microfiber towel. It's not a permanent fix but it makes the headlights sparkle for a few months. for a permanent fix you need to coat the lens.
Old Jan 17, 2014 | 06:32 AM
BLU-BY-U's Avatar
BLU-BY-U
Come over to my house and I will do you headlights for you! The toothpaste trick might work, but I have several plastic cleaners and the buffing wheel to clean them, plus the coating to make it last a year. Just make some cookies...
Old Jan 17, 2014 | 06:42 AM
ZippyNH's Avatar
ZippyNH
Use plastic cleaner or a headlight polishing kit...toothpaste varries in gritt lots from Brand to brand...use the wrong one...and it may cost $$ to fix....
Last edited by ZippyNH; Jan 18, 2014 at 03:12 AM. Reason: spelling...hate auto correct!!
Old Jan 17, 2014 | 09:45 PM
jbat66's Avatar
jbat66
I did the kit on my RV lights.... Big Difference!!!
Old Jan 18, 2014 | 02:56 AM
bavmotors's Avatar
bavmotors
I tried it with some cheap toothpaste I had laying around, didn't really work.
Old Jan 18, 2014 | 04:46 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Some toothpaste does contain properties consistent with very mild abrasives like baking soda.
Depending on how yellow they may be, best/longest lasting results have come from using professional grade headlight restoration kits. This one in particular.
BG Headlight Restoration Kit
If they just need some spiffing up, I have used auto polish before with satisfactory results.
Old Jan 24, 2014 | 11:24 AM
Joe_K's Avatar
Joe_K
What happened to all of the detailers that used to be out here? It looks like there's a bunch of misinformation in this thread. Most of the replies have part of the answer, but in order to properly restore your headlights you need to:
1. Sand/polish off the old, faded coating on the headlight.
1a. If you sand it, then you have to polish out the sanding marks
2(Most important). Reseal the headlight.
A lot of the products that you can pick up at AutoZone aren't going to last terribly long, I'm guessing 3 months to a year depending on conditions.
Now back to the topic at hand; I'm not sure whether toothpaste will work or not (I'm thinking some types with abrasives will) but it's not the best bet.
Hope this helps,
Joe
Old Jan 24, 2014 | 11:55 AM
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
Toothpaste is abrasive, and as others have said this varies from brand to brand. Tooth enamel is harder than the plastic lens covering of your headlight.
I'd use a commercial product.
Check this link for some more advice:
https://www.northamericanmotoring.co...eadlights.html
Perhaps the formula has been changed, but I had no success with Turtle Wax Headlight Lens Restorer.
Doc Pain
Mar 10, 2021 04:50 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
fkrowland
Sep 30, 2015 10:30 AM
MCarrera9
Sep 22, 2015 09:42 PM
1chaos52
Sep 21, 2015 05:42 AM
