R60 Hardwired Radar Detector
Old Jan 5, 2014 | 10:16 PM
Pablo_brown's Avatar
Pablo_brown
SO one of my projects was to hardwire my radar detector. I found this howto:
https://www.northamericanmotoring.co...ew-mirror.html
but I did not have the same color wire so i decided to connect it from the fuse box.
Basically I used this add a circuit device
and ran the Direct-wire Power cord up the pillar and tucked the wire in under the rubber seals.
Here is a picture with it plugged in. I used Fuse slot 43, since i don't have heated seats.
I felt pretty good until I realized the power from that fuse box does not shut off, SO for now I need remember to unplugged my Radar detector
If someone has a better place to make this run let me know. I thought about the cigarette lighter but I don't think my cord is long enough.
Also here is a picture of the wires in my car above the Rear view mirror as directed in the post above.
Old Jan 6, 2014 | 06:28 AM
kg4fxg's Avatar
kg4fxg
Fuses
Your box looks just like mine. I found the fuse row you are using stays on. But lower down they will cut off.
I check this with a multimeter. If you could fuse to lower fuses of a different color they should cut off. Very few stay on all the time. Worked for me.
Old Jan 6, 2014 | 07:08 AM
nd3boy's Avatar
nd3boy
I am using F44. It turns off when the car shuts off. However I am not sure what that symbol represents... But it works!
Old Jan 6, 2014 | 02:38 PM
52804x4's Avatar
52804x4
Attachment 86372
I believe that is the cigarette lighter/power plug in front of the cup holders.
Old Jan 6, 2014 | 04:11 PM
Pablo_brown
I will try slot 44 and see what happens. This would be better than splicing into any new wires. Anyone else who is doing this how are you grounding your connection?
Old Jan 6, 2014 | 08:05 PM
Pablo_brown
Fuse slot 44 was the key. which I believe is the cigarette lighter fuse.. Everything is off and all is well
Old Jan 7, 2014 | 05:21 AM
nd3boy's Avatar
nd3boy
Glad it worked! Where did you ground it? I had a horrible time finding a ground screw, so I connected it to the screw that holds the cupholder in place. Horrible solution but it worked, so I went with it.
Old Jan 7, 2014 | 06:52 AM
kg4fxg's Avatar
kg4fxg
Glove Box
Drop the glove box. You will see a screw to the right close to the fuse box. You need a Torx Screw to remove and tighten it.
Old Nov 13, 2015 | 05:09 PM
yeahdog31's Avatar
yeahdog31
F44 acc?
I know I'm late to the party, but I'm looking to hardwire an aftermarket satellite radio using a similar method. Unless I'm mistaken, my F44 fuse block only works when the engine is running, and not just when the key is in ("ACC" position). Can anyone comment on this or confirm that?
Which fuse location would be a good candidate for this? I would like the ability to run the radio without necessarily having to run the engine.
Thanks in advance.
BRebels
Electrical
20
Jul 31, 2016 02:10 PM
minimofo
Sep 30, 2015 12:26 AM
stoneunhenged
R58 :: Coupé Talk (2012+)
Sep 24, 2015 02:19 PM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
caiken
Sep 7, 2015 09:10 PM
