R50/53 about to hit buy on M2 Header... any reason why not to?
Old Jan 2, 2014 | 08:49 PM
GreekDrifter91's Avatar
GreekDrifter91
i am about to buy a megan racing header. any reason why not to? been trying to find videos of it, they don't sound bad when matched with a good cat-back. i plan on using an alta cat-back and the closest thing i could find was a video of a OBX header and alta cat-back and it sounded good.
been looking at threads and videos for a long time now, and dont seem to be many bad or good things. just a neutral response its not good but not bad... know what i mean?
my plans for it are to get it ceramic coated to keep some of the heat in. then maybe... maybe wrap it too.
Old Jan 3, 2014 | 05:09 AM
ZippyNH's Avatar
ZippyNH
I knew of a person who BOUGHT a M2 (BRAND) exhaust...it sounds good, was cheap..
BUT took a pro mechanic (at the shop they work) a couple of hours on a lift to "persuade" it to fit...not sure if they welded it on a very bad jig or just eyeballed it...not sure if it was just a similar name...
Cheap headers often have very cheap flex joint or poor quality slip joints...I would be cautious.
Before spending the kind of $$ you are looking at, I would start with the best part. It would suck to spend an extra $100-200, just to HAVE it fail....having a better PLAIN header...rmw maybe, might make more sense.
Old Jan 3, 2014 | 08:03 AM
astroBlackMetallic_Mini's Avatar
I've been reading about the Megan headers for a while, and so far I haven't found any problems in the forums. You'll prolly be fine.
Just to let you know, taking the old header off is a *****, and putting the new one in is worse. Yu can do it yourself, I did, but plan on about half a day. Fwiw, I had to put my headers in thru the top of the engine! So, if your doing it yourself, go that way and save the hassle.
Pm me if you want specific install details. Also, a header wrap should work, I did that on mine.
Old Jan 3, 2014 | 09:53 AM
GreekDrifter91
yea i figured as much....... im gonna take the heat shield off first and take a look at the studs and nuts to see if they are rusted to hell. if they are im not touching it! i do not want to deal with a broken stud on the head. then working the header out.
if they are in decent condition ill take it out. the exhaust system for me is still up in the air. on headers or not and which brand, because i do not want to spend 1000 for headers.
and im still debating on brand for the cat-back lol.
Old Jan 3, 2014 | 02:11 PM
I just put in a hi flow cat from eBay, then had the exhaust shop cut out everything back to the muffler so it's 2.5 all the way. Cost $150. They put in the o2 sensor and everything, and I have no cels at all. Just do that with Megan headers. It's all just metal man!
I can get a video here soon
Old Jan 3, 2014 | 02:20 PM
bavmotors's Avatar
bavmotors
My buddy had one of the cheaper race cats and about 4 months later the flex part busted open. You may have better luck though.
Old Jan 3, 2014 | 02:27 PM
I did some looking for a while. Found what looked like a good one, metal spun, 100 cells per sq inch, it opened up to 5" I'm the middle too, vs 4". Cost $110. So it wasn't that cheap, and my headers use that flexing cup joint setup with the spring bolts. No flex pipes in my setup!
Old Jan 3, 2014 | 02:31 PM
bavmotors's Avatar
bavmotors
Gotcha just wanted to add what I know, those flex pipes seem to be a weak spot.
Old Jan 3, 2014 | 07:41 PM
GreekDrifter91
please do.... also you dont have a muffler? its not to loud? im not for loud i want it to sound good. thats why im so damn picky lol i have been looking at exhausts sense i bought the car.
yea they do i still may go for it just dont know what to get for a cat back. i see way to much negative and positives for a lot of them. but alot of them have gone through a few iterations and seem good now.
Old Jan 5, 2014 | 03:08 PM
Ive got JCW muffs. Now it's just header to hi flow cat then straight pipe all the way back to the mufflers there. I'm liking the sound more and more each day
Old Jan 8, 2014 | 11:46 AM
TheBigChill's Avatar
TheBigChill
Biggest issue w/ Megan / M2 seems to be low quality flex sections. And, while I know this to be a big subject of contention, but I prefer "ball & socket" type flex sections over low quality braided wire flex sections. FWIW, I found my OBX header to give a nice kick-in-the-pants, and fit & finish were both above acceptable especially considering price.
Also, regarding aftermarket race cats, they typically don't last very long at all. That's not a rule, just an observation.
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
caiken
Aug 27, 2015 06:55 AM
L3Mix
Aug 26, 2015 07:00 PM
