R50/53 Coolant Leaking at Temp Sensor
Old Dec 20, 2013 | 06:40 AM
briggswill's Avatar
briggswill
2006 MCS. Anyone experience this point of coolant loss? Appears to be leaking from Coolant Temperature Sensor (first image below) and pooling in the tiny dip on the top of the transmission (second image) , and boiling off while driving. Also only appears to leak when engine is cool. Haynes manual doesn't mention an o-ring or gasket of any sort. Any known complications "behind" this leak? Any pro tips to fix? (Sensor is working properly) Or am I up for a straightforward swap of the part?
briggswill
Attached Thumbnails Coolant Leaking at Temp Sensor-image-1945434589.jpg   Coolant Leaking at Temp Sensor-image-591061401.jpg
Old Dec 20, 2013 | 07:02 AM
Here is the coolant temperature sensor. Look like this. I guess it could back out and leak, check to make sure its not loose. Also make sure the thermostat housing is not leaking or leaking on it.
#7 in the diagram.
Temperature Sensor Part # 13621486698
http://www.ecstuning.com/Search/SiteSearch/13621486698/
Old Dec 20, 2013 | 07:08 AM
briggswill's Avatar
briggswill
Thanks for quick reply ECSTuning! Will check to see if it's backed out slightly and double check t-stat housing. And thanks for link to the part, my friend.
briggswill
Old Dec 20, 2013 | 07:32 AM
You are welcome. Let me know how it goes.
Old Jan 4, 2014 | 02:19 PM
briggswill's Avatar
briggswill
Finally was able to catch it leaking actively today. Verified it is the thermostat leaking and running down onto the coolant temp sensor, as you suspected. Checking out the ECStuning site to go ahead and replace the thermostat, gasket, and housing while I'm at it. Looks like the Thermostat Replacement Kit is the way to go. Any deals I should know about before ordering?
briggswill
Old Jan 6, 2014 | 06:31 AM
Great, glad you pinpointed the problem. Also glad I could help.
We did last week have "Assembled by ECS" Kits on sale ( apart of our holiday sale ) for the thermostat housing, but that sale is over. No other offers I can think off. Never hurts to ask. Hope you get things fixed.
Old Jan 6, 2014 | 09:41 AM
briggswill's Avatar
briggswill
I ordered the kit nonetheless. Thanks for the help!
briggswill
Old Jan 6, 2014 | 11:35 AM
You are welcome. Just in-case anyone else need to know the thermostat replacement kits are here: Gasket comes with the new thermostat.
Part # 11537596787
http://www.ecstuning.com/Search/SiteSearch/ES2587243__ES2587245__ES2702798/
Old Jan 22, 2014 | 07:36 AM
lizandrooo's Avatar
lizandrooo
I replaced the sensor, gasket, thermostat and housing but I'm having a tough time finding the sensor torque specs... Any idea?
Old Jan 22, 2014 | 08:26 AM
Looks like 17nm for the temp sensor .
Old Jul 7, 2014 | 05:11 AM
briggswill's Avatar
briggswill
Finally got around to replacing the thermostat and housing. Discovered in the process the source of the leak. One of the three housing bolt holes was stripped out. Had to tap a new 7mm hole in place of the existing 6mm stripped hole and was able to get the problem resolved.
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
Khai
Feb 6, 2017 09:24 AM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Chippawaguy
Aug 19, 2015 10:59 AM
