R56 New clutch.... ouch... my wallet hurts....
Old Dec 12, 2013 | 07:10 AM
dmyer's Avatar
dmyer
Well I just replaced my clutch and flywell at 65K.... that was not fun... even less fun was using the same OEM clutch and flywheel to remain in stock class and paying $2,500 for that feature! My mechanic also replaced my leaking water pump and belt while he was at it for a total bill of $2,900 running my 2013 repair totals over $6K!
Is it my imagination or is the new replacement clutch a bit softer to engage? Maybe it was just the worn out one was a bit stiff for wear making the new one seem a lot softer.
Old Dec 12, 2013 | 07:18 AM
danjreed's Avatar
danjreed
New clutches are softer to engage. This is because of the lack of work harndening that occurs on the pressure plate springs as they age.
Old Dec 12, 2013 | 08:16 AM
The older clutch was harder to push in I think as the pressure plate is stiffer. People getting the new part which the Cooper S and the JCW share report that its much easier to push in. After driving an 2007 on the original I could tell a difference, but I remember driving a new 2007 ( back in 07') and it was harder also. That's what I noticed back in 07, but again it could be an aging of the pressure plate, possible?
https://www.northamericanmotoring.co...ght-pedal.html
http://www.ecstuning.com/Search/SiteSearch/21208607915/ES2634293/
Old Dec 12, 2013 | 08:24 AM
dmyer's Avatar
dmyer
The question is.... will it last longer than the original or should I look forward to another big repair bill 60K from now?
Old Dec 12, 2013 | 08:27 AM
Mindspin311's Avatar
Mindspin311
I have an 07 and my clutch is noticeably harder than the few newer cars I received as loaners.
Old Dec 20, 2013 | 04:54 PM
jimmy_racoon's Avatar
jimmy_racoon
My '05 R50 got a warranty clutch at 49k, but looks to be needing another at just over 121k...
Old Dec 20, 2013 | 05:29 PM
M'Cooper's Avatar
M'Cooper
Dmyer
What year is your MINI?
Old Dec 23, 2013 | 06:59 AM
dmyer's Avatar
dmyer
My R56 is a 2007... amazing how much better the car drives with a fresh clutch! But my wallet is still hurting!
Old Dec 23, 2013 | 07:22 AM
Ronin82's Avatar
Ronin82
I hate the fact that the center piece of that Flywheel is only help together by those eight rivots.
OutMotoring
Mar 3, 2017 06:29 AM
MasterShaftner
Nov 4, 2016 09:38 AM
embiggenedmini
Oct 15, 2015 12:36 PM
ir0nhid3
Sep 18, 2015 07:52 AM
