Drivetrain Door Brake/Check Strap
Old Dec 10, 2013 | 09:00 AM
AndyPWR53's Avatar
AndyPWR53
I've been meaning to fix my drivers side door for a while now. For those who have done this, is buying a new part always in order or is it just a matter of fixing/adjusting what is already there? Ideally I would like to attempt to salvage what I have rather than buying a new one. From what I've read its a very straightforward job, but is there any tips or tricks I should know before I start?
Old Dec 10, 2013 | 10:26 AM
AndyPWR53's Avatar
AndyPWR53
Don't know why I put this in drivetrain. Feel free to move this.
Old Dec 10, 2013 | 12:34 PM
There are two types of door brakes dependent on your year. Ones for up to 5/2003 and ones from 5/2003 on , for the Gen 1 MINIs. R50 R52 R53
Door Brake - Priced Each One per door -5/2003 production part # 51211166471
http://www.ecstuning.com/Search/SiteSearch/51211166471/
Door Brake - Priced Each One per door 5/2003 and up production Part # 51217176811
http://www.ecstuning.com/Search/SiteSearch/51217176811/
You can spray them and add some grease but it they still pop and click you have the parts linked here. I would also spray #2 and #3 hinge as they will help pivot the door better.
Also inspect the door brake and make sure the little bolt on the door and to the body are tight.
Old Dec 10, 2013 | 12:50 PM
AndyPWR53's Avatar
AndyPWR53
Perfect, thanks. For that price I think I might as well just buy one and be done with it
Old Dec 11, 2013 | 07:43 AM
Great, glad I could help.
Old Jan 15, 2014 | 05:29 PM
AndyPWR53's Avatar
AndyPWR53
Quick question...should I grease this thing before I install it? and if so what kind is best? I know I probably should, but I'm so sick of my door slamming on my leg that I want all the friction I can get at this point lol
Old Jan 16, 2014 | 07:56 AM
Dependent on what type you have above, they come pre-greased in certain locations. See the pics, black type is pre-gressed on the upper and lower spring mechanisms and pivot, metal finish and greased on the roller end and spring. You could use a little light brown grease similar to the sunroof grease. Or white lithium grease.
Old Jan 16, 2014 | 09:14 AM
JAB 67's Avatar
JAB 67
My April 2004 build date R53 uses the second type. Once it fails to function it is broken and can not be repaired. Easy to replace, however,provided that you know how to remove the inner door panel.
Old Jan 16, 2014 | 12:56 PM
AndyPWR53's Avatar
AndyPWR53
I bought the newer version. Thanks for the info guys. Rennline has a really good video for the installation of their door pulls that shows how the door panel comes off. Seems simple enough
Filmy
15
Jun 6, 2023 06:27 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Southern Marylander
Sep 3, 2015 05:46 AM
