Navigation & Audio Garmin GPS Install please help!
Hi Everyone,
I just received my Garmin GPS Mini Navigation Installation Kit but the only installation instructions available online show a four-wire harness and mine has a simple two-wire.
I'd like to install myself but don't know where to tap in for power. Any thoughts?
Rob
Rob
Cigarette lighter power under the console. I just use the lighter adaptor and routed the wire between the console and lower kick panel with the wire coming out beside the tach.
'Lighter Adapter', does that mean I need to purchase it or is the adapter just waiting for me to find it?
Rob
Rob
I use a Garmin power cable that has the adaptor that just plugs into the cigarette lighter. I have since acquired an adaptor that has two USB power outputs and I'll just use the Garmin USB cable for the GPS and use the other port to charge my phone.
Got it. I thought you meant tapping into the cigarette lighter circuit (from below so that it's unseen) and hardwiring that way. I have a wiring harness that I'd like to use but I don't know where to tap for power so that it is a clean install. It really should be a simple power tap as I have a positive and negative two-wire harness just waiting to connect
Rob
Rob
Amazon.com: Garmin 10-24V - 2amp Vehicle Power Cable: Electronics
Amazon.com: Dual USB Car Charger 3.1Amp 15.5W - 1.0&2.1A Universal Ports, Smart Power Supply For iPods, iPhones, Cell Phones & Tablet, Android Devices, Portable Cigarette Lighter Plug, Mobile Travel Charging Station 12V Input: Electronics
You could wire it over to the fuse panel. That's what I did when I hardwired my GPS. Got an add-a-fuse or some thing like that to create an additional spot.
Okay, install is complete- looks and works great.
Thanks for your help!
Rob
Rob
