R50/53 Strange Leak?
Old Nov 29, 2013 | 01:30 AM
rphox2003's Avatar
rphox2003
Strange Leak?
I just had my Mini up on lift for a front wheel alignment and the mechanic pointed out that the underside of the engine looked wet with what looked like oil?
Last week, I put a piece of cardboard under the front end (I do it every so often to be on the safe side) and the next morning when I pulled it out, it was spotless.
I've checked all fluids and everything is fine. Any ideas?
Old Nov 29, 2013 | 02:48 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Common issue. It seeps while driving, not dripping so no signs are typically left on the floor.
If you go to the "stock problems/issues" section of 1st Generation, there are plenty of posts on this topic.
Old Nov 29, 2013 | 02:56 AM
rphox2003's Avatar
rphox2003
What seeps while driving? Engine oil? Trans fluid? Power steering fluid? What?
Old Nov 29, 2013 | 03:06 AM
-=gRaY rAvEn=-
Moderator
Engine oil....oil pan gasket and crank sensor seal.
Other leaks at back near PS pump cooling fan is typically from Power steering fluid line.
Old Nov 29, 2013 | 04:18 AM
rphox2003's Avatar
rphox2003
I've checked all fluid levels and everything looks good.
So if I keep on top of my levels, is this something to worry about? Should I head to the service center ASAP? Or can I wait until the next scheduled maintenance?
Old Nov 29, 2013 | 05:53 AM
ZippyNH's Avatar
ZippyNH
My suggestion....
Wash the underside of the car off...usually a self service carwwsh ...just aim the hose under the car...drive for a couple of days or even a few miles...then the spotb of the leak will be more identifiable....a PS system leak or tranny leak would need yo be fixed asap...engine oil can usually wait a bit...
A slow leak can usually just be monitored...keep an eye on the leaking fluids level...and replacement put off till a second job is done that saves you some time and $$ by combining them....or the leak simply gets bad enough..I needs to be done.
Just a reminder....when the leak stops... You are out of the leaking fluid...a VERY BAD THING.
I I suggest you DO NOT TRY stopleak in a bottle...
The stuff has a mix of chemicals that swells seals and gaskets...all of them... And when present...they swell...but after they are depleted, or the oil changed, they shrink... And the seals (all of them) get smaller...and new leaks can start...and old leaks get WORSE. the crap is like crack in a bottle for your motor...you slowly need to use more and more to get the same effect and cannot stop......
Old Nov 30, 2013 | 06:08 AM
-=gRaY rAvEn=-
Moderator
Waiting too long on the oil pan gasket will just cost you more money in the long run.
From what I have seen, the cooling fan for the powersteering pump gets gunked up from this seepage of oil making moving fan parts suseptable to the accumulation of dirt/sand and other debris. When the fan seizes blowing the 5am fuse, the pump is no longer properly cooled eventually the rather expensive PS pump can/will fail.
If you replace the oil pan gasket, be sure to also order the bolts for this job. BMW's parts ordering system has these down as "ordering in conjunction with" the first generation oil pan gaskets. Although I have not seen an actual bulletin on this yet......
Here are the bolt part no's:
07-13-1-500-896 SCREW WITH Flange x11 @ 1.68 ea.
07-13-1-500-897 SCREW WITH Flange x1 @ 4.16 ea.
07-13-1-500-898 SCREW WITH Flange x1 @ 4.35 ea.
Old Nov 30, 2013 | 07:53 AM
rphox2003's Avatar
rphox2003
Thanks. I'll try to make it to the service center in the next week or so.
ian260
Mar 29, 2017 06:08 AM
Cruzer214
Oct 11, 2015 07:45 AM
Oct 1, 2015 12:13 PM
JAB 67
Sep 29, 2015 01:34 PM
donniedarko
Sep 29, 2015 01:16 PM
