Interior/Exterior Left footrest... what is beneath it? How do you remove it?
I was going to give it a good yank yesterday, but then I considered that there might be fuses behind it and if I broke the sucker... well... anyway.. see above?
If there is nothing behind it, I'm going to remove it for the leg room. :smile:
thanks.
thanks.
Pry the oval shaped piece off, you'll find two nuts to remove. Remove them and the plastic footrest comes off, leaving two threaded stems sticking out of the floor. The carpet has two holes cut in it for the two stems to come through.
From here you're on your own... :smile:
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
Aug 22, 2015 07:13 PM
