R56 Chattering wipers.
Old Oct 14, 2013 | 09:12 PM
amancuso's Avatar
amancuso
Chattering wipers.
Does anyone else have this problem? 2013 Cooper, no mods factory wipers and whatever they put in the fluid reservoir at the dealer. Already took it in once but the problem persists. It was so bad initially that the wipers were leaving black marks on the windshield!
Old Oct 14, 2013 | 09:33 PM
howzuh's Avatar
howzuh
Is there RainX on the windshield? If so, that can cause the chatter. I used a spray wax once on my windshield and it did the same thing. Sounds like there is a film of something on your windshield or blades or both. I would start by cleaning it really well. May have to replace your blades. My two cents. Hope it works out for ya.
Old Oct 14, 2013 | 09:39 PM
howzuh's Avatar
howzuh
Did some more research. It all seems to come back to something being on the windshield. Clean it with a good glass cleaner and microfiber towels. Do go through auto carwashes. Their waxes can build up on the windshield. You never know what is going on your car. Only wash with straight carwashes soap. Not the combo wash wax type.
Old Oct 14, 2013 | 10:46 PM
Kirby11's Avatar
Kirby11
Might be the angle of the wiper blade. Interesting video about fixing wiper chatter:
Old Oct 15, 2013 | 04:23 AM
richardsperry's Avatar
richardsperry
Bosch Icon blades, problem solved.
Old Oct 15, 2013 | 04:37 AM
Capt_bj's Avatar
Capt_bj
get a window scraper - basically a single edge razor blade with a handle and run it all over the glass. You won't believe what comes up. Then go over the glass with a clay bar.
Now it is clean . . .
Old Oct 15, 2013 | 04:55 AM
jhull413's Avatar
jhull413
I agree. Used a glass cleaner with RainX in it on my two week old MINI and the blades immediately began to chatter. I used Mother's California Gold Water Spot Remover to clean the windshield and no more chatter. I will never use RainX products again. If you don't have RainX on it, there must be some othe contaminant. Clean it with the Mother's product or use some of the other suggestions like a razor blade scraper or clay bar and I bet the chatter will go away. If the blades are also contaminated, try cleaning them with a good glass cleaner and if that doesn't work, replace them.
Old Oct 15, 2013 | 05:06 AM
Mcameron's Avatar
Mcameron
Wipe down your wiper blades with a rag an some mild cleaner( I just use my car wash soap).....
Mine had the same exact problem, blades were clattering and leaving black smudges on my windows.... I wiped off the blades and Sooo much grit and grime came off them, and I've never had the problem since....I just make it part of my car washing routine to give the blades a good wiped own. IDE recommend at least once a month.
Old Oct 15, 2013 | 05:12 AM
JAB 67's Avatar
JAB 67
In post # 3 above I think the poster meant to say 'do NOT go through automatic car washes.'
Old Oct 15, 2013 | 08:13 PM
howzuh's Avatar
howzuh
Good catch. Yes, that is what Meant. Do NOT.
Old Oct 16, 2013 | 09:39 AM
amancuso's Avatar
amancuso
Thanks for all the advice. All the suggestions above that say to thoroughly wash the window then change the blades... That's what the dealer did last time and the problem persists. :( (I do not have rain-x)
Old Oct 16, 2013 | 09:40 AM
amancuso's Avatar
amancuso
Originally Posted by Kirby11
Might be the angle of the wiper blade. Interesting video about fixing wiper chatter: http://m.youtube.com/watch?v=PHTjwpC...%3DPHTjwpC44zo
No worky!
Old Oct 16, 2013 | 10:30 AM
Kirby11's Avatar
Kirby11
Dang! I feel your pain - chattering blades are so aggravating. When the dealer changed the blades did they put on another set of OEMs? If so, it might be time to try an aftermarket design. richardsperry may be on to something with the Bosch suggestion - I had a "chirp" that persisted through two sets of OEMs and a set of PIAA Silicones, but it went away with a set of Bosches.
Old Oct 16, 2013 | 11:12 AM
cerenkov's Avatar
cerenkov
I have the same problem and have had the problem since day one when I got the car with 7 miles on it back in July. I've washed the car a dozen times or more (at least weekly) so there is NOTHING on the windshield.
I figure either the wipers blades are cheap or the arm angle needs to be adjusted like in the video.
I'll probably just replace the blades and see how that goes.
Old Oct 16, 2013 | 12:57 PM
JDPaddle's Avatar
JDPaddle
I would try the razor with a lubricant such as windex or soap as you wash. Then clay with the same. then glass cleaner. This is at a minimum if you are having issues.
My mini had tiny specks FROM THE DEALER NEW (I ordered the car) and the wipers made noise. Dont assume that a new car does not have stuff on the glass OR paint. visit detailing 101.
Ideally, follow with some glass polish if you have a machine to do so and follow that with "Hydrophic glass cleaner" like Stoner invisible glass cleaner which I recently found handy at my auto parts store.
Mine are silky smooth after the above treatment. Replace the wipers as a last effort.
Have some fun and search you tube for Drive Clean's glass cleaning segment. OCD at its best but isnt that what we're here for
Old Oct 16, 2013 | 01:13 PM
howzuh's Avatar
howzuh
Originally Posted by JDPaddle
I would try the razor with a lubricant such as windex or soap as you wash. Then clay with the same. then glass cleaner. This is at a minimum if you are having issues. My mini had tiny specks FROM THE DEALER NEW (I ordered the car) and the wipers made noise. Dont assume that a new car does not have stuff on the glass OR paint. visit detailing 101. Ideally, follow with some glass polish if you have a machine to do so and follow that with "Hydrophic glass cleaner" like Stoner invisible glass cleaner which I recently found handy at my auto parts store. Mine are silky smooth after the above treatment. Replace the wipers as a last effort. Have some fun and search you tube for Drive Clean's glass cleaning segment. OCD at its best but isnt that what we're here for
Nice.
Old Oct 16, 2013 | 03:58 PM
JDPaddle's Avatar
JDPaddle
Here's the link to cleaning and polishing your windshield. I couldn't post it from work earlier. This dude is IMPRESSIVE.
Old Oct 16, 2013 | 06:24 PM
amancuso's Avatar
amancuso
I tried the razor blade and clay and wash method today, so we'll see what happens next time it rains.
Old Oct 16, 2013 | 06:31 PM
cerenkov's Avatar
cerenkov
Ok, I'll try it too. Death to the chatter!
Old Oct 17, 2013 | 04:55 AM
jhull413's Avatar
jhull413
I wouldn't assume that the dealer really cleaned the windshield properly. Even the very best glass cleaners won't do the job. In order to properly clean, you need to do something more like the razor blade, clay bar, or Mother's water spot cleaner. I use MaGuire's glass cleaner which is one of the very best but after I am done with it, when I wipe my micro fiber towel across the windshield, I can feel drag. Then after cleaning with the Mother's product, I do the same and feel no drag. Try one of the extra cleaning methods on a small section of your windshield and wipe from the uncleaned section to the properly cleaned section and you will feel the difference.
Doc Pain
Mar 10, 2021 04:50 AM
jwmolmen
Oct 19, 2015 05:48 PM
Camaro108
Aug 25, 2015 02:44 PM
Accessory Products
Aug 25, 2015 10:03 AM
kensmini
14
Apr 22, 2003 02:41 AM
