R56 Turbo hiss normal?
Old Sep 23, 2013 | 06:01 AM
micromini234's Avatar
micromini234
I just noticed that my turbo makes a tiss sound at at like 9psi + is that normal?. I'm usually listening to music. I have no cel but it makes me wonder. The sound maker was also removed.
Sent from phone
Old Sep 26, 2013 | 10:26 AM
micromini234
I can't be the only one this happens to?
Old Sep 26, 2013 | 11:53 AM
countryboyshane's Avatar
countryboyshane
I'm not anywhere stock, but a turbo that's actively boosting will make a whistle/hiss noise. You can really hear it when you have an aftermarket intake. Not sure what you have.
Old Sep 26, 2013 | 12:00 PM
micromini234
I don't have a cai currently. It might be spooling? I've never has a turbo or super charger so I can't entirely tell. I noticed the other day. If its not the spooling it must either be the air charge pipe or the forge diverter valve
Sent from phone
Old Sep 26, 2013 | 12:53 PM
cerenkov's Avatar
cerenkov
I've never heard my turbo. I WISH it would make the supercharger sound though.
Everything is stock with exception of the intercooler, but that wouldn't affect the sound. My car never had a sound maker.
Old Sep 26, 2013 | 01:12 PM
micromini234
So you have a stock air charge pipe with the sound maker delete?
My air charge must have an issue then if you are not getting that sound?
6000pounds's Avatar
6000pounds
You all have heard your turbo but didn't realize you were listening to it. I heard my turbo after I rolled off the lot with the windows down. Hard to tell with the windows
Old Sep 26, 2013 | 01:19 PM
cerenkov's Avatar
cerenkov
The 2013 do not come with a sound maker, I still have the "muffler" installed in the charge pipe though.
Old Sep 26, 2013 | 01:20 PM
micromini234
I've never heard it with the windows down. Did your sound like tishhhh leaky sound near the passenger at + 10 psi (with the sound maker removed)
I'm not talking about the turbo faint whine. Mine sounds like a leak hiss, when my boost gauge was Leaking. Plus I get low acceleration at 80+mph but that might be normal.
Old Sep 26, 2013 | 01:21 PM
cerenkov's Avatar
cerenkov
This is extremely possible, my windows are almost always up.
Old Sep 26, 2013 | 02:30 PM
jomama's Avatar
jomama
are you talking about when you let off the gas or when you're on the gas? if it's a hiss sound when you let off the gas, then it's likely your diverter valve dumping boost. it's pretty subtle. it usually happens right after you let off the gas after being on it decently hard.
Old Sep 26, 2013 | 02:32 PM
6000pounds's Avatar
6000pounds
Well listening for it on purpose and not really being able to tell what to listen for I'm sure can play a big factor.
My last car had a 56 trim garret turbo that was almost 3 times as loud as these small mini turbo and was really evident.
Old Sep 26, 2013 | 02:37 PM
cerenkov's Avatar
cerenkov
Well listening for it on purpose and not really being able to tell what to listen for I'm sure can play a big factor. My last car had a 56 trim garret turbo that was almost 3 times as loud as these small mini turbo and was really evident.
Yeah I'm not quite sure what to listen for, but I'll try to listen for it (something). I still think the supercharged cars sound cool.
Old Sep 26, 2013 | 02:38 PM
micromini234
Mine occurs with my foot on the gas. An example is when I'm going my foot on the gas and leave or push harder ill get the tishh sound from what sounds like the passenger, there is an a air charge pipe currently, it's not the diverter valve I checked. And there are no boost leak. Is it possible to have an internal leak?
I appreciate that, it is a very distinctive sound like if you punctured an air mattress or turned the **** on a compress air tank. Its sounds like compressed air coming out somewhere.
Old Sep 28, 2013 | 01:39 PM
Summons's Avatar
Summons
Go on the hunt under the bonnet for split lines on the pressure side of the intake - turbo outlet to engine intake. The split may only open up when that magic 9psi is achieved. Pay close attention to clamps, intercooler, welds and seams.
We used to wrap clamps with foil, then run the pneumatic system and see if the foil was still in place after the run... This may not be practical in a Mini engine bay - use at your discretion...
Good luck...
E
Old Sep 28, 2013 | 03:02 PM
micromini234
Originally Posted by Summons
Go on the hunt under the bonnet for split lines on the pressure side of the intake - turbo outlet to engine intake. The split may only open up when that magic 9psi is achieved. Pay close attention to clamps, intercooler, welds and seams. We used to wrap clamps with foil, then run the pneumatic system and see if the foil was still in place after the run... This may not be practical in a Mini engine bay - use at your discretion... Good luck... E
But wouldn't that cause a cel?
Old Oct 1, 2013 | 12:05 PM
micromini234
I can't find it anywhere. What is the likely hood of the ecu cutting boost
Old Oct 1, 2013 | 03:16 PM
Systemlord's Avatar
Systemlord
No not always, when I was installing my AEM CAI I forgot to hook up the passenger side PCV hose and got no codes or check engine lights. I didn't even get any before I had the walnut blasting of intake valves, misfired badly and not one single light or code!
Old Oct 1, 2013 | 10:10 PM
micromini234
Update* thanks for the help everyone I finally found it I got so tired of it I ripped out all of the vacuum line tubing. Turns out it was one of the lines near the pressure converter not sure which one. But I guess everything around there is not metered air.
Now I just need to buy a new pressure converter because I ripped it off so hard I broke one of the nozzles on it and cause cel :/ yep that's my luck.
Sent from phone
Old Oct 10, 2013 | 11:45 AM
micromini234
New update* it came back again so it probably never left: my guest is that this is normal there are no engine lights and no leaks in either th diverter valve, vacuum lines Or the air charge pipe. My guess the metal air charge pipe is causing more noise then the rubber oem part
Sent from phone
Old Oct 11, 2013 | 07:45 AM
cdboss's Avatar
cdboss
Can you post a video of the sound? May be helpful for some of the individuals here. I'm also interested in hearing what it sounds like.
Old Oct 11, 2013 | 09:20 AM
micromini234
http://www.youtube.com/watch?v=TE2y_...ature=youtu.be
Here is a link to the video of the sound. However, the quality is quite terrible. It was taken with my iphone and through file conversions has lost quality; you may need to replay it a couple times. It is a lot louder in person as well. The first second or two is without the hiss so you can get a reference from that.
Colt45Magnus
Aug 27, 2024 05:03 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
Sean Pine
Massachusetts Motoring Club
Sep 2, 2015 08:16 PM
Sep 2, 2015 11:15 AM
