R56 Can't find 14x1.5 lug nuts
Old Sep 18, 2013 | 06:00 PM
HorizonBLueN18's Avatar
HorizonBLueN18
So I'm very much thinking about getting the WMW wheel stud kit but I can't find any reputable lug nuts in 14x1.5, all I keep finding is 12x1.5 either want to get blue since my car is blue or black bolts. Help!!!
P.s. how big of a spacer can you run on this set? http://www.waymotorworks.com/m14x1.2...-stud-kit.html
Old Sep 19, 2013 | 05:30 AM
v10climber's Avatar
v10climber
We have the 14 to 12mm stud conversion set. What do you mean by "reputable" lug nut? We just run a 5mm spacer up front but you could easily run much much more. Probably as much spacer as you would ever want to. 20mm should be easily doable.
Old Sep 19, 2013 | 05:35 AM
HorizonBLueN18
what do you mean by we? and i just don't want to get something that is really cheap aluminum that will strip easy or snap. and that's good because i want to run a 10mm in the rear so that's good news.
Old Sep 19, 2013 | 08:12 AM
quikmni's Avatar
quikmni
I use a 15mm spacer with the WMW 14 to 12 stud kit. I do have Wilwood rotors that might be slightly different thickness than OEM rotors. With the 15mm spacers the aluminum lug nuts fit perfect with the stud thread right at the end of the nut.
RAD USA (aka Otis) has many nuts:
http://otisincla.com/index.php?route...ry&path=117_68
Old Sep 19, 2013 | 08:28 AM
ra2fanatic's Avatar
ra2fanatic
I use Match Schnell 17mm lug nuts from EAS. Very reputable company here in SoCal and have these on my stud conversion kit because I wasn't a huge fan of the dumb keyed Muteki nuts that Way has optioned on their page.
http://www.europeanautosource.com/pr...e-17mm-lug-nut
Can either be for 12x1.5 or for 14x1.25. Call and they can ship them out for you.
Old Sep 19, 2013 | 09:12 AM
HyperBlueSTX20's Avatar
HyperBlueSTX20
http://www.sfxperformance.com/parts/GOR26641SD.htm
Here you go. 14mm x 1.50. Took me a while to find them for my other car.
Old Sep 19, 2013 | 09:55 PM
SimzMini's Avatar
SimzMini
I got my lugs from Otisincla.com They have tuner lugs this size also comes in chrome or black.
Attached Thumbnails Can't find 14x1.5 lug nuts-image-1478647312.jpg   Can't find 14x1.5 lug nuts-image-864281213.jpg
Old Sep 21, 2013 | 04:10 PM
TheMike's Avatar
TheMike
They look exactly like the Discount Tire lugs. You try them?
Old Sep 22, 2013 | 10:51 PM
Melangell's Avatar
Melangell
I have Way's http://www.waymotorworks.com/m14x1.2...-stud-kit.html which coverts to 14x1.5 along with the "dumb keyed Muteki nuts". What I don't like is the rust that forms inside the open nut. So, I searched and this is some of what I found:
Gorilla Wheel Lock Systems 71641NBC
Gorilla Lug Nuts 91147BC
Black Closed-End Bulge Acorn Wheel/Lug Nuts, M14x1.5, 19mm Hex, Qty 25
Muteki Lug Nuts - Black Closed Ended
The Muteki has this warning which gives me pause:
NOTE: LUG NUTS ARE MADE WITH TAPERED BOTTOMS SPECIFICALLY FOR AFTERMARKET WHEELS. DO NOT USE THESE TUNER LUGS FOR YOUR FACTORY WHEELS. WE NO LONGER ACCEPT RETURNS ON LUG NUTS FROM CUSTOMERS WHO ATTEMPT TO USE THEM ON FACTORY WHEELS. THESE LUGS ALSO DO NOT FIT ON SPECIAL WHEELS THAT REQUIRE INVERTED LUGS. WE WILL ALSO NOT ACCEPT RETURNS FROM CUSTOMERS THAT TRY TO USE THEM FOR THESE TYPES OF WHEELS.
I have OEM R119 16” 6-Star Twin Spoke wheels with 12mm front/15mm rear spacers. Will I have any problem with any of these nuts? The Muteki's??? especially since I already have Muteki open nuts???
Oh, Horizon BLueN18, I hoped I helped with your spacer question.
Old Sep 22, 2013 | 11:47 PM
RedAndBlackMiniS's Avatar
RedAndBlackMiniS
Old Sep 22, 2013 | 11:50 PM
Melangell's Avatar
Melangell
Obviously you figured it out...
Old Sep 23, 2013 | 12:22 AM
RedAndBlackMiniS
LordOfTheFlies
Oct 19, 2015 05:02 PM
MINI VINI
Oct 13, 2015 08:57 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
madmaxxed
Sep 2, 2015 03:32 PM
StuRat
Aug 24, 2015 06:24 PM
