R58 NM springs for JCW coupe
Old Sep 18, 2013 | 10:55 AM
pollila's Avatar
pollila
I just ordered some NM Engineering springs for my 2012 JCW coupe, I had seen that coupe dropped on those springs but I have been searching for pics and can't find them anywhere now... if anyone has an idea.
I am hoping 1.2" isnt too much and won't cause any other suspension issues because thats the only thing I am doing, putting springs on.
daily driver, just want the coupe to sit lower.
Old Sep 18, 2013 | 12:06 PM
NewCooperFanatic's Avatar
NewCooperFanatic
As long as you stay with a 205/45/17 or even a 215/40/17 tire you'll be good!
I would go springs but I love the size and look of 215/45/17, rubbing forsure with that size at that drop :(
Forgot to mention, keep an eye on your rear camber. You may or may not have to get rear control arms to get them back to spec. It's hit or miss for some folks.
Old Sep 18, 2013 | 12:12 PM
jkapinos's Avatar
jkapinos
I have them on my Roadster and like them a lot. Without rear control arms you will be about -2 degrees camber in the rear.
Old Sep 18, 2013 | 12:21 PM
pollila's Avatar
pollila
thanks for the tips. The NM guy told me I would be OK with only putting springs on, but thanks for the heads up on camber. I will of course check it out after and check the alignment.
is 2 degrees very significant if I let it be? I would assume it would just mean uneven wear on the tires, but at 2 degrees I wonder if it would be slow enough not to wear out quickly.
jkapinos do you have any pics posted up of your roadster with these springs?
Old Sep 18, 2013 | 05:13 PM
jkapinos's Avatar
jkapinos
I don't have any good pics, as I do not own a quality camera. All as I have are phone pics. The two degrees are not that bad as NM says to set it at - 1.8 degrees for aggressive street. I did get the H-sport rear control arms, but they are set to stock length right now. Tire wear is still good after a few thousand miles, but the handling is great. One more thing is the lowering springs will wear your shocks out faster than the stock springs. When that happens most just get the Koni yellows and mount the springs to them.
Old Sep 18, 2013 | 06:56 PM
CHKMINI's Avatar
CHKMINI
You will want adjustable lower control arms. I'm running 215-40 18 on my JCW Coupe with NM springs with only slight rubbing.
Old Sep 23, 2013 | 01:37 PM
pollila's Avatar
pollila
I cant figure out if putting 15mm wheel spacers on will be OK or not as well, with my stock wheels on JCW coupe with NM springs (1.2" drop)
Old Sep 23, 2013 | 01:59 PM
jkapinos's Avatar
jkapinos
Look in the R59 section. In the Black Toffee thread starting at post 102 you will see he added the NM springs with 12 mm spacers with no problem. Good luck.
Old Sep 23, 2013 | 02:11 PM
pollila's Avatar
pollila
jkapinos you're the best... exactly what I needed thanks so much!!!!
Old Sep 25, 2013 | 05:27 AM
DeeBee3's Avatar
DeeBee3
Does it have any detrimental effect on ride quality ?
i have fitted ebach lowering springs to previous cars, and found ride comfort was much harder.
Old Sep 26, 2013 | 10:16 AM
LTLMCPE's Avatar
LTLMCPE
I've had the NM springs on my JCW coupe for about a year and half now. Love the look with less wheel gap. No issues with the stock 205/45/17. I also have 215/45/17 on Sparco wheels for track and autox. In a few situations the tires have rubbed on outside inner wheel well fabric. This was only on track where I got up too much on curbing or at a track with excessive compression due to elevation change.
Ride harshness not much different. Bigger impact felt from run flats compared to non run flats.
Mine dropped about 1" to start then close to another 1/2" after spirited driving. I went ahead and did an H sport rear bar and control arms.
Old Oct 23, 2013 | 06:10 PM
NewCooperFanatic
Originally Posted by LTLMCPE
I've had the NM springs on my JCW coupe for about a year and half now. Love the look with less wheel gap. No issues with the stock 205/45/17. I also have 215/45/17 on Sparco wheels for track and autox. In a few situations the tires have rubbed on outside inner wheel well fabric. This was only on track where I got up too much on curbing or at a track with excessive compression due to elevation change. Ride harshness not much different. Bigger impact felt from run flats compared to non run flats. Mine dropped about 1" to start then close to another 1/2" after spirited driving. I went ahead and did an H sport rear bar and control arms.
Have any photos with the NM springs with 215/45/17 ???
Old Oct 25, 2013 | 07:07 PM
LTLMCPE's Avatar
LTLMCPE
Yes I do!
Old Oct 26, 2013 | 02:55 PM
NewCooperFanatic
Yes I do!
That's awesome, first picture I've seen with 215/45/17 lowered on NM springs.
Been contemplating doing that as I don't have a need for coilover(daily driver), but I'm running a 17x7.5 et 40 offset. Which might rub with a 215/45/17.
Are you running a fair amount of camber to reduce that scrub you get?
Old Oct 26, 2013 | 03:37 PM
MikewithaMini's Avatar
MikewithaMini
Here is an '07 S with NMs and 215/45/17. Stock shocks, adjustable RCAs. Dealer align = stock tolerances. Driven daily, no rubs.
Old Oct 29, 2013 | 08:22 PM
LTLMCPE's Avatar
LTLMCPE
Just the small amount of front camber you can get by removing the pin that comes stock on the strut tower. The shop did a good alignment too.
Old Oct 29, 2013 | 08:33 PM
maacodale's Avatar
maacodale
I think you'll be fine. Our son has the NM springs on his JCW Roadster and it sits nice. I'm pretty sure 215s would fit. My R56 has H&R springs and it's lower and 215s fit and the wife has Eibach springs on her Clubbie and 215s fit. Daughters Cabrio is stock...for now!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
FrostyFox
Oct 28, 2015 02:06 PM
dyeLucky
Sep 11, 2015 10:41 AM
dyeLucky
Aug 7, 2015 07:10 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
