R56 Battery Died
Old Sep 14, 2013 | 09:17 PM
Mini40's Avatar
Mini40
Battery Died
Was rear ended this afternoon...thankfully no major damage. However I had hazards on for about 45 minutes waiting for police to finish report etc. I was ready to leave, and I went to start the car and there was nothing. Police helped to jump the battery and the car started. Could the hazards drain the battery?
Old Sep 15, 2013 | 07:59 PM
Slave to Felines's Avatar
Slave to Felines
They use electricity, so... Yeah, they could do it. Not sure that 45 minutes worth should be able to drain a fully-charged battery, though. Worth having the battery tested if you can pull it out and take it to your auto parts store.
Old Sep 16, 2013 | 06:15 AM
lowsid3r's Avatar
lowsid3r
Really also depends on how old the battery was how hard you were hit. A good jolt could finish an old battery off. If you have a charger charge it up then take it over to auto zone or something and ask them to do a free test with some sort of carbon pile load tester.
To answer your question yes they could but there are alot of variables.
Old Sep 16, 2013 | 06:26 AM
MikewithaMini's Avatar
MikewithaMini
Also, believe it or not, hot weather can be more taxing to a battery than cold! It seams counter intuitive but back in the day when I had my shop, we'd change out a ration of batteries on the first hot snap of the year.
Old Sep 16, 2013 | 07:40 AM
Rick w's Avatar
Rick w
Make sure the impact didn't crack the batt. and cause it to leak better check!
Old Sep 16, 2013 | 08:10 AM
DneprDave's Avatar
DneprDave
Our MINIs have really wimpy batteries. I've run mine flat just listening to the radio while I was washing and waxing it. So I can imagine that leaving the flashers on for a while would run the battery flat.
Dave
Old Sep 16, 2013 | 08:20 AM
MikewithaMini
Every few days I put mine on a trickle charger. It typically shows a 20-30% discharge. No, no power leakage found.
Old Oct 3, 2013 | 10:15 AM
brazenone's Avatar
brazenone
If your battery is four years or older, you should probably be shopping around for a replacement anyway.
wildwestrider
11
Jan 29, 2016 05:06 PM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
