R50/53 Service engine soon light on
Old Sep 12, 2013 | 10:29 PM
rocysuja's Avatar
rocysuja
What would cause this light to come on? I have an R50 2003 mini. It has all the coolant hoses change and just had an oil change. Will need a new exhaust soon.
Old Sep 12, 2013 | 10:44 PM
minsanity's Avatar
minsanity
Check what fault code popped.
Old Sep 12, 2013 | 10:48 PM
bshapperd's Avatar
bshapperd
There are so many things that could cause this light to come on. Ideally you need a code reader ( scan guage , etc) or pay a shop to do it. This is only half the battle as you'll then need to fix the problem.
I would check that the level of coolant is acceptable as you've had recent work done here. Also check that your gas cap is tightened properly - if not, air will leak by causing the check engine light to illuminate.
Old Sep 12, 2013 | 10:53 PM
AlexQS's Avatar
AlexQS
When the oil change was performed, was the countdown-miles-clock till next inspection (service) reset?
Old Sep 13, 2013 | 04:52 AM
Saltysalt's Avatar
Saltysalt
any autozone will scan you for free
Old Sep 13, 2013 | 06:31 AM
ZippyNH's Avatar
ZippyNH
On s gen1 it will not set a service engine light....the miles to go when you turn the keys goes to a negative number....
But no yellow light....
To the OP.... Till you get the car plugged into a code reader....it is just a guess...there are THOUSANDS of codes......
Old Sep 16, 2013 | 11:47 AM
zum27's Avatar
zum27
Hi, on mine it turned out to be the pre-catalytic converter O2 sensor. The dealership wanted around $360 to replace it, but you can find the part for around $25.
Old Sep 16, 2013 | 05:39 PM
ACallahan's Avatar
ACallahan
Please point me in the direction of the $25 o2 sensor.
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
oldkid6
Aug 11, 2015 08:13 PM
