Changing from RunFlats to Regular, do you have to replace all 4?
Hey all, Newbie here and need some advice. I've had my clubman S for about 4 months. 2008 with only 24k miles. Got a flat yesterday (memorial day) and didn't realize I had run flats. The tire has a huge gash and won't hold much air. So, after reading a bunch of these forums, I realized I should just replace the tires with non-runflats (my front two tires were in need of replacing anyway), but my back tires are still ok.
Should I replace all four since the they are different type of tires?
Any new 195/55 - 16's that are hot right now? (commuter / non-track / good in rain)
Can I "really" drive on the run flat for 10 - 20 miles?
Thanks all!
Thanks all!
Depends on your budget-
In 205/55-16 which will fit stock wheels and suspension-
see
http://www.tirerack.com/tires/survey...wws=N&showcm=N
The top 5+ are all good but with various prices, best compromise commuter tire is Continental ExtremeContact DWS (good comfort and good in nearly all weather including cold) while Bridgestone RE970AS is good all round tire with value, emphasis on good handling in any weather.
Michelin Pilot Sport A/S 3 (Ultra High Perf All Season tire), W or Y speed rated
and
Michelin Pilot Sport A/S 3 (High Perf All Season tire) V or H speed rated
Are both new tires that will perform well for street use. The V or H speed rated versions are cheaper and come in OEM sizes, they still work fine and are a good value.
see
and
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
