R56 Something moves
Old Sep 2, 2013 | 06:00 AM
Minitonka's Avatar
Minitonka
Something moves
Inconsistently when shifting from 2nd to first at stop there is a movement "upfront" that I can feel through the pedals. 2012 MCS with 9,000. Doesn't happen all the time and of course not at dealer.
It is a "bump" but barely audible.
Thanks!
Help.
I have replicated it over and over, a couple of times with parking brake on. Just not everytime.
What could this be? The Mini is tight otherwise!
Old Sep 2, 2013 | 12:56 PM
bmx045's Avatar
bmx045
engine mount bumping back and forth, 2nd to 1st can be a jolt thus the engine torquing forward
Old Oct 31, 2013 | 03:23 AM
Minitonka's Avatar
Minitonka
Fast forward mechanic could not duplicate.
Drove base loaner and it was quite tight and missed the slop between shifts.
It was in for 10k service & gave a reading that it needs new rear brakes. It didn't. They did software upgrade. Guess what? All the slop is gone. Could have been the advance and how the engine responded to lifting throttle but its tight.
It also had the water pump replaced. It was leaking. While a wear & tear item this is unusual to me with this low mileage.
Happy motoring, Peeps
Old Oct 31, 2013 | 04:32 AM
Herleman's Avatar
Herleman
Talk to Way. He has some motor mounts and torque arm inserts that will cure this movement in a heartbeat. Mine did it to. I added just the lower torque arm inserts. Its all gone. The total cost was about $70 and it took about 20 minutes.
Old Oct 31, 2013 | 05:11 AM
If you are ever looking to tighten up the lower engine mount, we carry the Powerflex version. Big bushing insert and the little bushing for the lower engine mount. With 9,000 miles its unlikely its has wear in the rubber , but the Powerflex does tighten it up.
Here is the lower mount:
Lower Engine Mount / Rubber
http://www.ecstuning.com/Search/SiteSearch/22116783094/ES41748/
And the Powerflex : Performance and Race ( performance is for most people unless your tracking all the time ).
Polyurethane Engine Support Bushing - Large
http://www.ecstuning.com/Search/SiteSearch/PFF5-207/
Polyurethane Engine Support Bushing - Small
http://www.ecstuning.com/Search/SiteSearch/PFF5-206/
Good luck and happy motoring.
Old Oct 31, 2013 | 05:46 AM
Minitonka's Avatar
Minitonka
Does it change the feel of the vehicle?
Its stated that with one lower bushing company you get steering wheel shake when aircond is on.
Old Oct 31, 2013 | 06:46 AM
Herleman's Avatar
Herleman
I have had no issues with vibration or shaking of any kind with the inserts -- they've been there 60,000 miles now.
Old Oct 31, 2013 | 06:49 AM
Minitonka's Avatar
Minitonka
Thanks!!
Old Oct 31, 2013 | 10:28 PM
Minitonka's Avatar
Minitonka
Again thanks everyone.
Having installed aftermarket braces & bushings on earlier performance cars I am familiar with their benefit.
May I remind you all with a big smile that the software upgrade fixed the problem. It may not have made it autocross ready but it transformed the car from original/new to one with no slop. It was built late 2011 into 2012 as a 2012 model.
It could be throttle mapping as it drives away from a stop without any feathering of the clutch and throttle that was previously required.
I took this to be the nature of the beast and adapted my technique to get a smooth take off.
Now it's just easy.
randeez
Oct 5, 2015 09:23 AM
Pedro99
Oct 3, 2015 10:56 AM
MINI Stupor
Oct 1, 2015 11:36 AM
point665
Sep 29, 2015 12:41 PM
Emnotek
Sep 29, 2015 07:37 AM
