Navigation & Audio OEM bluetooth on an '11 R56?
I've searched until my mouse hand is cramped. Will the OEM bluetooth upgrade fit our 2011 cooper S with base radio but with satellite radio? The website says up to 8/2010 build, but who knows if that's the last car it'll fit, or when the website was last updated. Anyone?
Here is the information I have. Produced from 8/2007 to 8/2010 . Works with Navigation and CD boost radio which is on base and HiFi systems.
Up tp 8/2010 MINI have the display with the single ****. Face display is silver.
8/2010 on have the double ****. And the face display is black.
So you will know what interface you have.
Here is the kit itself:
MINI Bluetooth Retrofit Kit W/ USB/Audio Interface Part #65412152530
http://www.ecstuning.com/Search/SiteSearch/65412152530/
Then you will need this.
ULF Module High Part # 84109229740
http://www.ecstuning.com/Search/SiteSearch/84109229740/ES1906933/
And Here is the latest Y cable.
http://www.ecstuning.com/Search/SiteSearch/61122338491/ES2641685/
For people who have convertibles:
Trim Panel For Steering Column Part number 51442758451
http://www.ecstuning.com/Search/SiteSearch/51442758451/
Hands Free Telephone Mic Part # 84109167397
http://www.ecstuning.com/Search/SiteSearch/84109167397/
Here is a thread where the Sirius and Bluetooth are talked about. The Sirius install kit is NLA.
https://www.northamericanmotoring.co...bluetooth.html
And a little more about install.
https://www.northamericanmotoring.co...elivery-2.html
And here is the install page with install PDF.
Post # 22 has the PDF. And then talks a little bit about the install.
If it does work you will need additional coding at a MINI dealership.
Thanks and hope that helps.
Double **** like the one above, is the 8/2010 + in production. You should have a sticker in the door jam that under the VIN number or near it shows the production month and date. 8/2010 on it does not work for.
I'm 1/11 build date, looks like it won't work.
Yep the kit will not work then.
But since you have the newer system, the ULF module only above is shared on the 8/2010 + installed factory Bluetooth. I am not sure if you could get the module and wires exist for the 8/2010+ models. I am curious to see if there is cables in the box under the seat on 8/2010+ if they are pre-wired in any way. Like its pre wired and then needs programming, if you ever get a pic of the inside black plastic box on the passenger side , I would like to see what wires are there.
And we are in the Gen 1 section, so hopefully the moderator can move the thread to Gen 2.
blackie
Oct 2, 2015 07:41 PM
Mr Wiggles
Aug 18, 2015 07:14 PM
tippin
Aug 5, 2015 08:43 AM
