Random Dying
Old Aug 23, 2013 | 07:54 PM
rennwerkes's Avatar
rennwerkes
Random Dying
My wife pulls into the parking garage and our 06 MCS dies. She starts it up and everything is fine.
Anyone have any idea what might have caused this?
Car is running fine. Coil is new as are spark plugs and wires.
Old Aug 23, 2013 | 10:32 PM
ZippyNH's Avatar
ZippyNH
So....did it stall?
Dash lit up? Or no lites?
Just happen once? A few times? It was a blue moon this month....so once in a blue moon?! Lol.
Old Aug 23, 2013 | 10:40 PM
rennwerkes's Avatar
rennwerkes
Sorry, here are more specifics
Just did this once
No lights that were different
Old Aug 24, 2013 | 07:21 AM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by rennwerkes
Just did this once
There’s a saying that if it only happened once, it didn’t happen.
Is it possible she hit the key with her knee and it inadvertently shut the car down?
///Rich
Old Aug 24, 2013 | 12:33 PM
rennwerkes's Avatar
rennwerkes
My wife is capable of doing many things but I'm nearly positive she didn't hit the key inadvertently. LOL!
Old Sep 1, 2013 | 06:57 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Title of post/thead is "random dying" so are we to assume then this has happened more than once ?
Old Sep 1, 2013 | 07:42 AM
ZippyNH's Avatar
ZippyNH
....Just did this once.......
Guess it might have been a random occurrence.....we did have a blue moon last month...kinda fits the whole not normal mini advertising campaign...... Or maybe..
Call it stray electrons or cosmic particles from a sunspot..maybe a slug of water from condensation....
Maybe even you wife trying to get you worried about the car....kinda planting the seed to get something newer in a few months....kinda like mind control!!
Just wait and see what happens!!
Old Sep 1, 2013 | 09:17 AM
-=gRaY rAvEn=-
Moderator
IF:
Manual trans = "Ya gotta rev the bloody thing !" Maybe it just stalled out, dunno not enough info.
Automatic = ?
UFO flew over garage......
Old Sep 1, 2013 | 11:26 AM
rennwerkes's Avatar
rennwerkes
Originally Posted by -=gRay rAvEn=-
IF:
Automatic = ?
Car has auto trans.
Car hasn't stalled since.
A previous poster mentioned that she might have hit the key which I'm thinking may be a good possibility given that she's making some tight turns in the garage.
Old Sep 14, 2013 | 12:18 PM
rennwerkes's Avatar
rennwerkes
Just and update on this thread.
The stalling has happened two more times since the first time.
No indication when it's going to happen.
Car just dies for some reason and starts up fine.
I was wondering if it might be the ignition switch?
Or a relay?
Any ideas/advice is appreciated.
Thanks!
Old Sep 14, 2013 | 01:38 PM
MiniWii's Avatar
MiniWii
Cam shaft position sensor will cause this sometimes
Old Sep 14, 2013 | 02:09 PM
ZippyNH's Avatar
ZippyNH
That and just reach around....
Make sure plugs are tight...check everything you can reach....ecu plugs, etc....
Battery is snug, and ground wire is tight....both on the battery and the main ground by the engine mount.
Old Sep 14, 2013 | 02:17 PM
rennwerkes's Avatar
rennwerkes
Thanks!
I forgot about the camshaft sensor.
I've seen this happen on Mercedes and BMW but then again none of those cars come close to the cost of maintenance I've experienced on this MINI!!! :(
I'll also double check all the connections.
Thanks again!
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
spec35
39
Jun 19, 2017 05:54 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
