R50/53 WMW Tensioner Stop Install
Old Aug 21, 2013 | 01:43 PM
JoeGravelle's Avatar
JoeGravelle
I did not see any install instructions for the WMW tensioner stop and would like to know if I can install it while the tensioner is out of the car. I have my new tensioner, ready to install, and the stop sitting in the box.
or do I have to install the tensioner assembly and then install the stop?
thanks
Old Aug 21, 2013 | 01:50 PM
AlexQS's Avatar
AlexQS
thanks
Mine was the WMW steel strap (not the cable kind). I bolted it on top (outside) the hydraulic damper tube. The tensioner spring part was mounted to the car when I did it, and with a box end wrench, not enough room for a ratchet. Probably easier to do it before you put the tensioner on the car.
Old Aug 21, 2013 | 02:07 PM
04_Indi_Mini_S's Avatar
04_Indi_Mini_S
thanks
I just did a new tensioner and WMW stop a few weeks ago. I opted to put the stop on with the tensioner installed in the car first as I did not want to chance eating the tensioner spring. It isn't difficult to get the stop on with the tensioner in the car. Open ended wrench, and 5 or so minutes.
Old Aug 21, 2013 | 03:17 PM
JoeGravelle
Ill do it with the tensioner on the car.
Old Feb 14, 2014 | 12:44 AM
RHcoopers's Avatar
RHcoopers
What if I'm doing the stop and replacing the strut bushings?
Old Feb 14, 2014 | 05:37 AM
JoeGravelle
You'll be fine?
Old Feb 14, 2014 | 08:04 AM
RHcoopers's Avatar
RHcoopers
You'll be fine?
Haha. Fair enough. I'm just not sure if having that locking pin inserted will allow me to completely remove the tensioner strut without any issues... Other than space. I'm replacing the old bushings with delrin.
Old Feb 14, 2014 | 08:18 AM
Z06_Pilot's Avatar
Z06_Pilot
thanks
I did not get any instructions with a product I bought from WMW as well. They told me in an email they don't provide instructions due to liability concerns with getting sued
Old Feb 14, 2014 | 08:37 AM
johnvanrees09's Avatar
johnvanrees09
very simple to install, I did mine with the tensioner off the car, tho it can be done while on the car. Just take the 2 bolts out that hold the tensioner shock absorber on and put the metal strap on under the bolts and put the shock absorber bolts back in.
Old Feb 14, 2014 | 10:52 AM
RHcoopers's Avatar
RHcoopers
So as long I a have the locking pin inserted I the hole to keep the tensioner spring loaded I can remove the shock absorber and put my new bushings and stop on without removal of the tensioner? I'm using a wmw pulley so the collet is built in.
Old Feb 14, 2014 | 03:49 PM
johnvanrees09
Yes, when the locking pin is in, you can remove the shock absorber with no problem. You do not need to take off the tensioner, tho it is only held on with 3 bolts and is easy to remove. You can access everything through the wheel well with the wheel well cover off.
Old Feb 15, 2014 | 08:27 AM
minsanity's Avatar
minsanity
Please be warned that if your tensioner struts are busted, those stops will break from vibration stress. Google " Now I know why belt tensioner stops break".
Not saying same will happen w/ the WMW, which I presume is better engineered, but if your struts have no more resistance, it's time to change the assembly. The Gates tensioner is just $70 or so over at Amazon. It's practically OEM.
Old Feb 15, 2014 | 08:38 AM
RHcoopers's Avatar
RHcoopers
Originally Posted by minsanity
Please be warned that if your tensioner struts are busted, those stops will break from vibration stress. Google " Now I know why belt tensioner stops break". Not saying same will happen w/ the WMW, which I presume is better engineered, but if your struts have no more resistance, it's time to change the assembly. The Gates tensioner is just $70 or so over at Amazon. It's practically OEM.
Thanks! Tensioner is 10k old so I should be okay
Old Feb 15, 2014 | 08:40 AM
RHcoopers's Avatar
RHcoopers
I'll have to remove it. Some reason I can't slip the pulley tool on.
Old Feb 15, 2014 | 09:20 AM
ACallahan's Avatar
ACallahan
"The Gates tensioner is just $70 or so over at Amazon. It's practically OEM."
Not practically, It IS OEM.
adrchn
Aug 13, 2019 02:11 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
squawSkiBum
Oct 2, 2015 09:21 AM
12magnum
Aug 31, 2015 08:22 PM
