R56 Aeroforce Interceptor in my 2008 R56S. Any experience?
Old Aug 9, 2013 | 10:36 AM
Jolyrogr's Avatar
Jolyrogr
So I'm looking to add an Interceptor gauge to my R56. I dont really track the car. I've done it a couple times but it's not something I do often. Really just looking to add a bit of fun gadgetry to freshen up my day to day driving a bit.
In looking at the list of supported parameters from Aeroforce website for this car, it looks pretty slim (given what little I know of this stuff). This list is attached.
Now, I'm a bit of a noob when it comes to tuning and all that, so really, from this list, or in anyone's experience that runs these gauges, is there anything here that really would be worth my time in getting this gauge to monitor? Anything that I can use for "fun" daily driving, such as when to get an optimal upshift time, or stuff like that? I know this probably sounds kinda dumb, but like I said, really looking for something to add a bit of fun to the car. I realize I wont really be utilizing the real power of the gauge but I'm ok with that. However, if its really a total waste just to get like one parameter to look at, then I dont want to TOTALLY waste money on something like that.
Any input?
Attached Thumbnails Aeroforce Interceptor in my 2008 R56S. Any experience?-screen-shot-2013-08-09-at-12.27.59-pm.jpg
Old Aug 9, 2013 | 02:27 PM
richardsperry's Avatar
richardsperry
Look at the Scangauge 2
Old Aug 9, 2013 | 03:26 PM
Jolyrogr's Avatar
Jolyrogr
I have. Basically the same thing right? I like the aeroforce because installed it will look more stock and match the current setup better.
Old Aug 9, 2013 | 05:49 PM
Slave to Felines's Avatar
Slave to Felines
The text in the photo is too small for me to read.
In my SGII, I usually have fWT (coolant temp), LOD (load), MPG (trip MPG), and VLT (voltage).
For fun, I would swap out MPG for something like AFR (air-fuel ratio) if available, and if I had the MINI-specific version I'd probably use the oil temp readout.
Old Aug 9, 2013 | 06:21 PM
Hoosh's Avatar
Hoosh
Sorry, no experience with the Interceptor. I have the updated SGII. I keep EOT (oil temp), Boost, and Intake temp up. I switch the 4th to MPG or A/F depending on my mood. Doesn't look like the Interceptor does oil temp without an external sensor.
Old Aug 12, 2013 | 07:40 AM
Jolyrogr's Avatar
Jolyrogr
The Scangauge does boost without an external sensor? Looks like the aeroforce doesn't do that either. Nor Lateral G's. Does the scanguage do lateral G's?
Old Aug 12, 2013 | 09:11 AM
Hoosh's Avatar
Hoosh
No lateral Gs on either it seems. I use my Harry's Lap Timer for in car video which reports G forces for me. The SG takes all the info as calculated or sensed via the OBDII port, so no external sensors needed. As to how SG reports boost (direct measure vs calculated value), I would have to defer to someone else with more knowledge in OBD info.
Old Aug 12, 2013 | 09:31 AM
Jolyrogr's Avatar
Jolyrogr
Cool. But it does do boost though? As far as an upshift indicator or something to suggest upshift at optimal time, would engine load work for that?
Old Aug 12, 2013 | 02:42 PM
Hoosh's Avatar
Hoosh
SG does report boost/vacuum.
Old Aug 12, 2013 | 02:52 PM
Jolyrogr's Avatar
Jolyrogr
Cool. Thanks for the input. Just ordered mine actually.
QuickCooper
Dec 29, 2016 06:46 PM
LAcooper
Sep 22, 2015 10:03 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 14, 2015 04:19 PM
kjd186
Sep 9, 2015 10:02 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
