R50/53 Exhaust leak help Urgently needed!
Old Aug 7, 2013 | 03:31 PM
jamez's Avatar
jamez
Hi Everyone,
It appears I have an exhaust leak. I was underneath the car and from what I can tell the leak is "south" of the first O2 sensor at the back of what looks to be a small 'can' or resonator. I'm not sure if that's the Cat.
Either way, the leak is coming from the entire circumference of this part. Is there supposed to be some kind of cap, or filler or something to fill/cover this gap? The sound is coming from it (I used a length of tubing to locate the leak).
Here are a few photos:
Without flash:
with flash:
My main problem here is the fact that I am scheduled to do a dyno run first thing on Friday morning and the local Mini dealer doesn't have time to get it in to look at it.
1. Will this affect performance? (it appears to have -4th gear seems gutless)
2. Is this something that an exhaust shop can fix?
3. Is there something missing in these photos?
Any help would be greatly appreciated.
Old Aug 7, 2013 | 08:11 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes that is bad.
Yes you will loose torque with it leaking there.
Maybe your exhaust shop can fix it, seen it done before.
Yes you should replace the entire header.
Old Aug 21, 2013 | 05:58 PM
dphiggs's Avatar
dphiggs
My R53 just did this last night so I took it apart and swear there should've been a clamp missing (fell off) but I guess not. what did you end up doing?
Old Aug 21, 2013 | 06:09 PM
jamez's Avatar
jamez
I haven't updated with photos of the result, but I had to replace the entire header and catalytic section (both of the cans are cats).
It's a crazy expensive piece ($1800 + core and labour), but my mechanic found a used one (50,000kms) and installed it for $1200 all-in.
Mine is a very clean brake around the pipe. The break is not inside the can/cover. In theory if I could figure out the angle it could be welded/fixed
Old Aug 22, 2013 | 07:00 AM
jamez's Avatar
jamez
Here are some photos of the point of separation
Old Aug 22, 2013 | 07:10 AM
Helix13mini's Avatar
Helix13mini
That's a very common failure. For customers that aren't feeling very rich, we weld them back together. It's not a permanent fix, but they've lasted surprisingly well--like years. The cost is about a tenth of the cost of a new header. BTW, there's an underlying cause to this failure: whipped motor mounts. When you fix or replace your header, also fix your motor mounts.
Old Aug 22, 2013 | 07:36 AM
jamez's Avatar
jamez
Motor mounts - that's a good thing to know! Daymn, I wish I knew that earlier...
Old Aug 22, 2013 | 08:11 AM
xsmini's Avatar
xsmini
Mine did that, welded it back together, doing fine now. Didn't know the motor mounts were the cause, next project on my to do list now
Nik
KrisMiss
Jan 3, 2016 02:02 PM
elightbo
Aug 17, 2015 01:50 PM
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
ti22fjc
Aug 9, 2015 05:49 PM
