bolt strength for harmonic pulley puller question
Old Jul 28, 2013 | 10:50 AM
GoThingNC's Avatar
GoThingNC
Can I use 3 M6 bolts from ace hardware or should I get high strength bolts from Fastenal to prevent the risk of the bolts snapping while using the puller. Here is a photo of the bolts I have.
Thanks.
Attached Thumbnails bolt strength for harmonic pulley puller question-img_20130728_134004_922.jpg
Old Jul 28, 2013 | 01:40 PM
mrbean's Avatar
mrbean
Considering the relatively low price of high strength bolts and the aftermath of trying to extract the broken Ace bolts, I'd go ahead and order the high strength ones.
Also try www.McMaster.com They sometimes have better pricing.
FWIW, the bolt you pictured (A2-70) is a medium grade stainless steel. It will probably work, but I wouldn't risk it.
Old Jul 28, 2013 | 06:03 PM
xsmini's Avatar
xsmini
That's what I used, bent the hell out of them, but they worked.
Nik
Old Jul 28, 2013 | 06:56 PM
GoThingNC's Avatar
GoThingNC
Thanks everyone. I will be picking up the high grade bolts from fastenal since they are near my office. What length do I need, 2 inch?
Old Jul 29, 2013 | 09:10 AM
jhiggs26's Avatar
jhiggs26
M6 in Grade 8.8 and length depends on your puller width and your crank pulley(early thick or late thinner pulley). Looks like you have a 2006 so thinner crank pulley. You can stack washers or cut bolts to make it work with your pulley. I'd say at least 65mm or 2.5"+.
Jeremy
Old Jul 29, 2013 | 09:27 AM
GoThingNC's Avatar
GoThingNC
Thanks Jeremy
I was able to source a better harmonic pulley puller from my neighbo.
It is a little smaller and thinner than the ones found at the local auto parts store plus the center bolt of the puller fits into the crank pulley hole
Found a link on Motoring Alliance but it will not paste here.
Old Jul 29, 2013 | 09:29 AM
GoThingNC's Avatar
GoThingNC
Add
motoring alliance . com
/library/1st-generation-mini-cooper-how-to-3/replacing-the-crank-pulley-101/
cw40342
Oct 6, 2015 05:07 PM
ShadyCoop
Aug 24, 2015 06:05 AM
JPMontes3
Aug 23, 2015 01:26 AM
Aug 21, 2015 10:41 AM
Lt. Dan
Aug 10, 2015 08:23 AM
