Drivetrain Pulley Modification. Is it harmful?
Old Aug 22, 2015 | 11:27 AM
cw40342's Avatar
cw40342
I'm looking to change my harmonic balance to the super damper 2% overdrive and I want to put the smaller pulley on the supercharger. Are any of these harmful towards the performance of the car? Should I just keep them the stock size?
Old Aug 22, 2015 | 05:19 PM
evoq007's Avatar
evoq007
Unless the stock crank pulley needs to be changed i would not add 2% overdrive to the crank.
As for the supercharger pulley I would recommend the following based on what type of fuel you might have available.
91oct = 15%
93oct = 17%
I would not go above these because the supercharger will just run too hot. Obviously check to make sure the car is healthy in general before increasing boost.
I have run both 17% and 15% pulleys on my two R53's with no issues.
Old Aug 22, 2015 | 05:39 PM
bavmotors's Avatar
bavmotors
Either should be fine just don't go over a total of 17% reduction, unless you plan on using meth.
Old Aug 22, 2015 | 07:16 PM
cw40342's Avatar
cw40342
Ok my MINI has almost 100k on it now I've been good about changing the supercharger oil and maintenance. The reason I'm asking is im about to take the supercharger off again and I figured I would go ahead change the pulley and the harmonic balancer with the super damper one because I've heard such good things about it. I'll change the pulley but go with the stock size on the super damper.
Old Aug 22, 2015 | 08:09 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
No the pulley is the old tried and true mod for the supercharged MINI. If your car is going to break it will break with or without the pulley. Do the pulley and enjoy it. The Crank pulleys are very prone to failure as the rubber fails all the time in them, the ATI Damper is the best replacement for it. We normally go with with the standard size then our 16 or 17% pulley.
Old Aug 22, 2015 | 11:07 PM
Eric_Rowland's Avatar
Eric_Rowland
Take the supercharger off AGAIN?
Why was it off before, and why again?
Old Aug 23, 2015 | 06:10 AM
cw40342's Avatar
cw40342
Originally Posted by Eric_Rowland
Take the supercharger off AGAIN? Why was it off before, and why again?
I have the recharger by imperial MINI but I have had a issue with it so I'm taking it off to send it back and have it checked out.
Old Aug 23, 2015 | 06:12 AM
cw40342's Avatar
cw40342
I've been reading the reviews on your website I'm definitely going with the ATI I just wasn't sure about the 2% overdrive option.
On a side thanks for the advice on the sway bar when I called the H-sport comp is pure love!!!
Old Aug 23, 2015 | 04:31 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
If you plan on any track duty, stick with the 15%. If just street, then the 17% will be o.k.
Old Oct 6, 2015 | 04:46 PM
audio131's Avatar
audio131
pressing on new crank pulley
Hi. When pressing on a new crank pulley wether its steel or aluminum is it a good idea to use a little bit of loctite on the shaft??
Old Oct 6, 2015 | 05:07 PM
bavmotors's Avatar
bavmotors
for the crank pulley you just want to use a new bolt which will have some Loctite on it already.
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
