Drivetrain Losing TONS of power with use of AC
Old Jun 28, 2010 | 05:38 PM
jirsty's Avatar
jirsty
Does everyones mini do this?
My car runs pretty horrible with the AC on, I would say I lose a good.. 35% of my power, maybe, probably more.
When the AC is on, the car is harder to drive (floods easy) and the throttle is MUCH less responsive.
I honestly can't stand driving it with the AC on, so whenever I have to go some where I arrive sweaty.
Why is this? Why does the AC effect it so dramatically?
This is my first summer with the car, and it might be a rough one..
Also, could it be because of the bpv? I think I need to replace it anyway, I only build 10 psi..
https://www.northamericanmotoring.co...-this-now.html
Or, since I have 84k miles should I just go all out and get it rebuilt, port and polished or whatever..?
opinions?
Old Jun 28, 2010 | 06:11 PM
Da_Ghost's Avatar
Da_Ghost
The A/C does take quite a big chunk of power to run! I don't like driving off a stop with it on, it takes longer to go! It's mainly because when the A/C clutch engage, it drag some of the power of the engine! As much as I hate how much I feel the effect of it when it's on, I wouldn't get rid of it :p
Old Jun 28, 2010 | 06:17 PM
jirsty's Avatar
jirsty
Yeah haha, that is what I have to do.
When I am stopped at a light I watch for the other light to turn yellow to know to turn off my AC before I have to take off.. heh.
Old Jun 28, 2010 | 06:22 PM
hsautocrosser's Avatar
hsautocrosser
I've driven mine 128 miles all with the a/c on in 99 degree weather. 33mpg and no complaints of any kind, let alone of running "pretty horrible." Shrug.
Old Jun 28, 2010 | 06:25 PM
jirsty's Avatar
jirsty
Are you talking about your R56?
Old Jun 28, 2010 | 06:45 PM
hsautocrosser
Of course. When you wrote "everyones mini" did you mean 1st gens only?
Old Jun 28, 2010 | 07:01 PM
jirsty's Avatar
jirsty
Oh no, thats fine, I was just making sure.
I thought you might have another mini since this is the 1st gen section =]
Old Jun 28, 2010 | 07:03 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
You could be noticing this MINI A/C phenomina more due a poorly fitting BPV plate. With a 15% pulley reduction your boost numbers should be closer to 14-15 lbs. That is where I would start first.
Generally we only use the A/C on hot days, and as we all know the hotter the day ( esp depending on what altitude you are at ) the more power loss we will experience....a combination of the two is noticible but not to the point of having to shut down the A/C just to drive normally.
Old Jun 28, 2010 | 07:06 PM
kcle730's Avatar
kcle730
hahah, its sooo horrible with the AC on >< its hard to go from a STOP, i wud always stutter on it. i might have to try ur method and turn it off on a stop =P
Old Jun 28, 2010 | 07:13 PM
jirsty's Avatar
jirsty
Yeah, I know that but I lose a LOT of power, pretty much suddenly when I turn off the AC and get it back about a second after I turn the AC off.
I will start by changing the BPV.
I think I want to try the DTBPV, but I am a little afraid I won't like it, I don't know why, I guess it is worth a shot.
and by a poorly fitting BPV plate, do you mean the piece that covers and uncovers? and getting a new BPV would fix it if that was the problem, right?
I know I need a new BPV anyway, so I will get on that soon!
Thanks.
Old Jun 28, 2010 | 07:19 PM
jirsty's Avatar
jirsty
haha, its the only way, sounds like we have a similiar issue, mine is really hard to not make it stutter on take off with the AC on, unless I rev it really high, then I still take off SLOW!
I hope the BPV helps, I know it will with the AC off, but I hope it does on as well.
Old Jun 28, 2010 | 09:13 PM
soccerbummer1104's Avatar
soccerbummer1104
if you dont like the dt bpv you'd probably be a first not to
Old Jun 29, 2010 | 12:07 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Both my MINIs did this.
I hardley ever run AC, unless I want my hair gel to dry.
For spirited runs or traffic jams and track days I always turn it off or even run heater on lowest dial. DTBV did not do nothing for AC power loss.
Old Jun 29, 2010 | 01:27 AM
user 7082082's Avatar
user 7082082
I thought I was the only one running the heater in traffic.
Old Jun 29, 2010 | 08:47 AM
MINIdave's Avatar
MINIdave
In my '03 JCW, due to the tall gearing in first gear, it was difficult to pull away from a stop smoothly - turning off the compressor helped considerably - but eventually I just got used to it and got where I could pull away smoothly without over revving it. No question, you notice the drag of the A/C much more in the early cars, and it really affects the fuel mileage. Mine would drop as much as 3-4 mpg when the weather got really hot and I was using the A/C all the time, but it was a price I was willing to pay to be cool in the car.
In my '09 Clubman S OTOH, you hardly notice whether it's on or off and it doesn't seem to affect the mileage either....
Old Jun 29, 2010 | 09:00 AM
CrazyIvan's Avatar
CrazyIvan
I think anyone with a 4cyl notices the loss of power with the air on. I fitted a home made intercooler sprayer, and while sitting at a light hit the mister a few times and can tell a noticeable difference when pulling a way.
Old Jun 29, 2010 | 10:57 AM
Keano's Avatar
Keano
I did a test of this on a Mustangs dyno - with AC on I noticed a loss.... was done by mistake so did another run to get a proper figure and the difference was 5whp less with the AC running c.f. off I have 211whp so 5whp isnt quite a 35% loss though... perhaps something is wrong with your car then... :(
Old Jun 29, 2010 | 11:01 AM
jirsty's Avatar
jirsty
I definitely lose more than 5 hp.
seems like the supercharger takes a really long time to kick in.
I hope the BPV will help, I know I should be losing a little power with teh AC on, but I really really don't think it should be as much as I am.
I am going to order the BPV today, I will post again when I get enough time to get it on there.
Old Jun 29, 2010 | 03:23 PM
-=gRaY rAvEn=-
Moderator
OP said he was running a 15% pulley and only showing stock boost of 10lbs......that said, a BPV could be the answer to his pressure loss.
As far as a DT BPV helping with acelleration issues when A/C is on ? He should be showing higher numbers of boost with or without the A/C on.
Old Jun 29, 2010 | 03:31 PM
HRM's Avatar
HRM
I fall into the "don't notice much" catagory, but then again, I am old...really old. Remembering the 4 cyl pigs of the 80's, the Cooper does really well.
Off the line, there is definitely a big difference in the amount of gas you have to give it as well as off the line power. After I am going though, I don't notice anything. This seems totally normal to me.
Old Jun 30, 2010 | 01:09 AM
Keano's Avatar
Keano
With that in mind I would say its not the AC thats the problem then - hope the BPV sorts it for you
Old Jun 30, 2010 | 08:15 PM
jirsty's Avatar
jirsty
I'll find out pretty soon hopefuly, I ordered the DTBPV.
Now I just need to find some time to put it on heh.
Old Jul 9, 2010 | 12:20 AM
Trickle X's Avatar
Trickle X
Had the same problem. Twincharged it, and it wasnt a problem. It's more of a compressor issue then anything.
as for only a 5hp difference with it on, at peak hp you wouldnt notice it as much, but across the curve im sure its a lot more than 5 hp and that you will notice as everyone here is stating.
Old Jul 9, 2010 | 03:15 AM
Keano's Avatar
Keano
Love that approach; my car feels a bit sluggish... I know, lets twincharge it Love it
Old Jul 10, 2010 | 08:58 AM
ellcapitan's Avatar
ellcapitan
The biggest difference I notice w/ the A/C on is a very notchy (for lack of a better word) throttle response. Smooth clutch engagment is nearly impossible due to the "all-or-nothing" nature of the throttle response with it on. Otherwise, power-drop is about what I would have expected from an engine this small when off-boost.
I've learned to live with the idea that A/C=daily commuting/leisurely cruising, and harder/sportier driving=sweatty brow and sticky palms. My last car was an early (1.6) Miata... Believe me, the MINI (R53, in my case) is actually not that bad with the A/C on!
