R50/53 intake causing drop in mpg?
Old Jul 1, 2013 | 08:14 AM
DTMR's Avatar
DTMR
just installed my alta cai and i have a 15% pulley, my consumption meter is saying that I am getting way less mileage than before and I dont know why. Is it because of all the extra air going in? I know it could be my driving but I mean it went down a lot. Has anyone else noticed this?
Old Jul 1, 2013 | 10:17 AM
Eleo's Avatar
Eleo
From what I've read, a cold air intake should have the complete opposite effect. If you don't see a boost to gas mileage then it should be about the same. How much is "a lot"? I've hit low 30s when taking longer trips on the highway, but tend to stay around the high 20s with my half-city/half-highway commute. How big of a drop are you talking about?
Old Jul 1, 2013 | 10:19 AM
DTMR's Avatar
DTMR
like I went as low as 16 at one point and I dont know why, I never went that low before and I still havent hit 30 mpg ever :( but it never went this low till I put the alta intake in
Old Jul 1, 2013 | 11:01 AM
kaneguy's Avatar
kaneguy
With that big change in MPG I would suspect that that vacuum line came loose. Double check you installation. A CAI should be beneficial to gas mileage.
Old Jul 1, 2013 | 11:04 AM
ZippyNH's Avatar
ZippyNH
A CAI should get you a slight mpg gain....a pulley the same....but with the newfound power and sound...folks tend yo become leadfoooted....that and I bet you are running your ac tons more now in the heat....
Old Jul 1, 2013 | 11:41 AM
Eleo's Avatar
Eleo
16 is really low based on my own experience. I've never seen anything under 25, on my CVT, and it's only improved with new spark plugs and performance mods... Even with AC/heat on, driving aggressively, 16 seems crazy low.
Have there been any performance issues?
I would take everything I installed out and go back through the installation process just for a sanity check.
Old Jul 1, 2013 | 12:41 PM
DTMR's Avatar
DTMR
i never use AC unless im on the parkway
Old Jul 1, 2013 | 12:47 PM
OldGameFreaK's Avatar
OldGameFreaK
Try a new tank of gas. I got some crap gas a few weeks ago an it really messed up my gas mileage. New tank and i'm back up to normal.
Just a thought
Old Jul 1, 2013 | 02:31 PM
ZippyNH's Avatar
ZippyNH
Driven even moderatly hard....an S (gen1)s a low 20's/high teens mpg car...
Some do better...heck I average 30 mpg...sometimes 32 on the highway...little traffic....but mid 25 is normal... Lower in traffic or getting aggressive...18-20 would not be uncommon....if I had wide tires or heavy rims...bet 16 would be about right....
Still....check you connections.
Old Jul 1, 2013 | 03:32 PM
DTMR's Avatar
DTMR
this is so confusing! My connections are fine, I only use sunoco or shell gasoline, I changed all the fluids in the car, I don't know what I am doing wrong. This weird drop in mpg is puzzling
sevin
May 2, 2026 06:11 AM
W0TM8
Dec 19, 2019 07:50 AM
MasterShaftner
Sep 1, 2017 07:23 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
