R52 AC compressor locked up and took out harmonic balancer, pulley questions?
Old Jun 12, 2013 | 08:24 PM
JSmith1717's Avatar
JSmith1717
As the the title says my ac compressor locked up and ended up spinning the harmonic balancer. Now I got now ac and when I accelerate it won.t go above 5psi and on comes check engine light and into limp mode. I haven't pulled the codes but it's probably from to much fuel from the harmonic spinning.
Now my question is should I just go ahead with a cravenspeed 2% crank pulley and do a 16% supercharger pulley and replace the ac compressor? Also I picked up and belt a while ago new for $5 and it's a 4060537 Goodyear gatorback would that belt work with the 2% crank and 16% supercharger? Or should I just go ahead with the 15% and 2% crank and would that belt work for that?
Old Jun 12, 2013 | 09:52 PM
stage1scott's Avatar
stage1scott
are you SURE thats what happened? USUALLY the harmonic balancer is about torn through and engaging the a/c compressor does it in-the reason you are in limp home with lights on is the crankshaft speed (near zero on the belt) as measured by the timing sensor, is way out of whack for the programmed parameters of the alternator and supercharger. WMW has a nice std or 2% harmonic balancer that still keeps the crank dampened, you should use one of them. Your a/c will return to normal once the belt drive is returned to normal
Old Jun 12, 2013 | 10:29 PM
JSmith1717's Avatar
JSmith1717
No the compressor is locked, trust me
Old Jun 12, 2013 | 10:33 PM
JSmith1717's Avatar
JSmith1717
But I'm tearing down the car tomorrow morning and will check the compressor to see if it will spin or not.
Either which way the harmonic balancer has to get replaced, compressor clutch still engages and disengages so I could wait off on compressor if it is bad, it is a convertible
Old Jun 12, 2013 | 10:34 PM
JSmith1717's Avatar
JSmith1717
And I just replaced the alternator 2 weeks ago
Old Jun 13, 2013 | 06:16 AM
stage1scott
The reason I ask is, when mine broke (crank pulley) it was a hot day and turning on the a/c is what finished the crank pulley, putting me into limp home and a wait for a tow truck. the compressor was fine once I got into repairs but apparently the stress of turning it on is what fiished off my obviously nearly seperated crank pully. As mentioned,I like the solid ones Way sells.
Old Jun 13, 2013 | 07:21 AM
JSmith1717's Avatar
JSmith1717
yeah it was like 100' and got off highway then it started acting up
Old Jun 13, 2013 | 07:29 AM
K20K1LLA's Avatar
K20K1LLA
Whichever crank pulley you go with, make sure that it is, as stage1scott mentioned, dampened. There is a huge debate among the MINI community of whether these engines actually require a dampened crank pulley. Theoretically the dampened pulley will cut down on vibrations that could kill the supercharger. In my experience, the ATI damper I fitted last year made my engine purr like a kitten and I have solid engine mounts. It's also available over-sized like the Way damper but it is on the expensive side of reasonable.
Old Jun 13, 2013 | 02:28 PM
JSmith1717's Avatar
JSmith1717
Well I got down to the ac compressor and it still will spin so maybe it isn't lock up and the crank pulley spins around. Off to M7 to get a crank pulley tomorow, they about 30 min drive from me.
Old Jun 13, 2013 | 02:44 PM
K20K1LLA's Avatar
K20K1LLA
Lucckkkyy, every time I order MINI parts I have to wait a minimum of 4 days to have stuff shipped
Old Jun 15, 2013 | 04:13 PM
JSmith1717's Avatar
JSmith1717
Stage1scott you were right got me a M7 2% crank pulley everything working great now
Old Jun 15, 2013 | 08:39 PM
stage1scott
well, even a blind squirrel finds a walnut now and then! I was married 16 years so I am not used to being told I am right, thanks! glad it worke dout ike that, comnpressors are expensive
Old Jun 16, 2013 | 06:31 PM
JSmith1717's Avatar
JSmith1717
Yeah I was pretty sure it was they compressor cause I drove over 100 miles down they highway with it like that, amazed that I made it home
thebordella
Aug 31, 2015 01:37 PM
blackie
Aug 23, 2015 08:44 PM
damncajun
Aug 17, 2015 08:25 PM
PrimePower
Aug 16, 2015 06:29 PM
