Error in secret menu
Old Jun 5, 2013 | 10:53 PM
a2oc's Avatar
a2oc
Hi all,
My 09 R56 S has recently visited the dealer for a few issues.( 600 miles ago, replaced timing chain kit and left fuel level sensor) When I get my car back, theres no errors in the secret menu. After I fill it up today ( was looking at the fuel level originally) , I've discovered there are 2 errors codes in there. They are 9319h and 931ah. It doesnt have any warning light. Anyone knows what's the fault code about? It has water pump and timing chain replaced in the history.
P.S. Its a MINI CPO vehicle.
Thanks,
Frederick
Old Jun 6, 2013 | 06:27 AM
yetti96's Avatar
yetti96
What exactly are you calling the secret menu?
Old Jun 6, 2013 | 09:14 AM
a2oc's Avatar
a2oc
the one with holding the reset trip computer button. section 14
Old Jun 7, 2013 | 11:21 AM
bmx045's Avatar
bmx045
I am not aware of this menu. Could be a chassis code, like ABS or airbag related. In my opinion, if you have no half power lights or CEL's I'd relax.
Old Apr 8, 2024 | 12:58 PM
jcook's Avatar
jcook
Error code 9319h
Hi, did you manage to find out what the error codes meant. I’ve got the code 9319h on my mini and can’t seem to find it anywhere online. Thank you!
Old Apr 8, 2024 | 02:45 PM
a2oc's Avatar
a2oc
Dont know what was the fault, but the dealer changed the whole indicator wiper stalk clock spring assembly and the fault went away. That was 10 years ago, so i dont have anymore info.
Old Apr 11, 2024 | 08:40 AM
Northern's Avatar
Northern
Per:
https://www.bmw-syndikat.de/bmwsyndi...ammierung.html
931Ah :
Fehler Signal Tank Rohdaten Füllstand Rechts
~~Error signal tank raw data fill level right
9319h:
Fehler Signal Tank Rohdaten Füllstand Links
~~Error signal tank raw data level left
Hard to find anything more. I don't know if this is simply from running the fuel tank too low, too full, a rogue communication error, or some plausibility error.
I wouldn't worry about it.
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
dutchhome
Sep 30, 2015 07:17 AM
ericf1993
Sep 26, 2015 03:58 PM
keen
GP Talk
Sep 16, 2015 05:00 PM
