R50/53 Weird alignment with ie fixed plates
Old May 29, 2013 | 09:11 PM
micromini234's Avatar
micromini234
Does this alignment seems off to anyone else , the camber I mean.
Old May 29, 2013 | 10:05 PM
msjulie33's Avatar
msjulie33
When I had them, the camber was close to -1.5 both sides as I recall, and toe was 0...so yeah not expected there
Old May 29, 2013 | 10:13 PM
micromini234
So it's not just me... That's really strange then 1.0 degree off, any ideas as to what's going on
Old May 29, 2013 | 11:07 PM
AlexQS's Avatar
AlexQS
Old May 30, 2013 | 03:10 AM
danjreed's Avatar
danjreed
Very off... does the car pull left?
-1.9 is going to eat tires. Thats way to neg.
Old May 30, 2013 | 04:01 AM
micromini234
Not that I can think off the tope of my head, ill test that later. And this alignment was done last year and I've been driving it daily, I haven't notice any unusual tire wear. My tread is about 3/16s of an inch on all four wheels. I definitely didn't install the shocks backwards and I'm fairly certain the camber plates are in the right the spots and not backwards( the arrows are point backwards away from the car
Old May 30, 2013 | 05:32 AM
minsanity's Avatar
minsanity
Watch toe more than camber.
Old May 30, 2013 | 05:55 AM
Braminator's Avatar
Braminator
Here is what the factory specs are for reference
Front Caster
Left = 4.92 +/- 0.50 / Right = 4.92 +/- 0.50
Cross caster = 0.00 +/- 0.50
Camber
Left = - 0.50 +/- 0.42 / Right = 0.50 +/- 0.42
Cross camber = 0.00 +/- 0.50
Total toe
0.30 +/- 0.08
0.15 +/- 0.04
Rear
Left = -1.53 +/- 0.50 / Right = -1.53 +/- 0.50
Total toe
0.20 +/- 0.07
Thrust angle 0.00 +/- 0.17
0.40 +/- 0.13
Old May 30, 2013 | 06:25 AM
micromini234
I think I misphrased all of this. Basically I just want the camber I'm missing on the left. I'm trying to figure out if it was something I screwed up or if the plate is
Old May 30, 2013 | 06:29 AM
v10climber's Avatar
v10climber
IMHO you'd be hard pressed to eat tires with just -1.9 of camber. Maybe if you put 60-70k miles on a set of tires and just did highway driving. The wife dailies on -2.5 with no issues.
To the OP. There is a small amount of camber adjustment available in the factory setup just from slop in the bolts mounting the top of the strut to the strut tower. I don't think there would be enough to get you even side to side but it should get you closer. Just keep in mind if you change the camber it will change the toe so you'll have to reset the toe. Honestly though if you're not racing or driving aggressively I wouldn't worry about it
Old May 30, 2013 | 06:30 AM
minsanity's Avatar
minsanity
If you had any mushrooming & wasn't addressed, that might be a factor.
Old May 30, 2013 | 06:32 AM
micromini234
There shouldn't be. I added craven speed stds a long time ago so they should be all flat.
Old May 30, 2013 | 06:36 AM
minsanity's Avatar
minsanity
Now, that's puzzling.
Old May 30, 2013 | 07:23 AM
micromini234
Thanks v10 ill see what I can do with that. But yeah It doesnt seem to make much sense. the casters not adjustable neither is the camber.. everything is installed right..and not like broken to my knowledge (I took the the wheel of to take a look). ' And im a very aggressive driver I lost grip on a downward U shaped turn going 60 last night.. So I dug up the last alignment.
Old May 30, 2013 | 03:06 PM
danjreed's Avatar
danjreed
While your experiences are your own. I'm saying what life has taught me in doing alignments, and owning lowered cars for a long time now.
Old May 30, 2013 | 03:09 PM
danjreed's Avatar
danjreed
Disagree, both are huge tire wear angles, and camber causes a pull... While toe will cause your wheel to be off center, or change thrust angle.. But not a pull, just an off center wheel.
Old May 30, 2013 | 04:30 PM
danjreed's Avatar
danjreed
So I was thinking..
After carefully looking at this.. I can tell you... what they did...
The reason why the car feels "ok".. is because the toe is correct (wheel is straight).. however... front to rear cross camber is whacked.. the LF is counteracting the LR... pull same with the RF and RR... pull.
Camber pulls to the more positive side (least negative..)..
No good alignment tech would ever leave camber reading like that and walk away.. I'd be embarrassed to hand out a printout like that to a customer.
When every you do an alignment.. you always do rear camber 1st.. then toe.. then front camber, caster, and then toe..
Toe is the last adjustment, not the 1st... To me it looks like they only adjusted toe... what shops call "A toe and go" job..
That or.... They added weight to the car to make it look like things changed..
They had the car lifted (not jounced) when they did the baseline measurement (AKA the before)..
Stuff on your car is bent.
Or the tech is a moron who totally left critical measurements out of whack..
Old May 30, 2013 | 06:13 PM
micromini234
Yeah, im pretty sure it was the tech and whatever he did.. I went under and checked out everything...needless to say I wont be going back there anytime soon.
andrewjg1994
Jan 29, 2021 07:45 PM
Drumsound
Sep 4, 2015 04:53 AM
Aug 27, 2015 12:25 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
