R50/53 lean afr
lean afr
so at wot i run 19.1 to 20.9 but when my inner cooler comes off my afr go down to 10.1 to 12.9 any idea what could be the problem ive got 550cc injectors bigger head sprintex super charger dinan intake with a samco inlet hose a detroit tuned bypass valve and a mynes tune. i was told the vacume hoses coild be switched
Sorry but your decsription is confusing, if you're getting that high of a reading @ WOT the first thing you should check is the vacuum line to the fuel regulator, sounds like you have a major loss of vacuum either it has come off or you have an open line somewhere.
Pull the I/C & re-check that all the vacuum lines are tight & routed correctly, if you did the VGS mod, make sure that not only is the line to the diaphram on the BPV tight but that the line you disconnected is plugged or capped well.
Sorry, I can't find the picture right now but routing should be like this:
(No Boost Gauge)
Stock:
One line from Intake Manifold to Fuel Regulator
One line from Base of BPV to BPV Diaphram
VGS Mod
Insert "T" in line between the Intake Manifild and Fuel Regulator
-One line to Intake Manifold
-One line to Fuel Regulator
-One line to BPV Diaphram
Plug or cap the line or port on the base of the BPV.
(No Boost Gauge)
Stock:
VGS Mod
misterbl
Sep 16, 2015 11:22 AM
