R56 Helix FMIC & Coolant Temps
Old May 5, 2013 | 07:23 AM
bimpower's Avatar
bimpower
I'm thinking about purchasing one but concerned about the blockage that a stepped FMIC does.
For those of you that have installed the Helix FMIC..or any stepped FMIC. How did it affect your coolant temps? Any experience is appreciated.
UPDATE: 5/13/13
Scored a great deal on a used Helix FMIC off ebay and finally got it installed over the weekend. I have about 300 miles on it so far and have done some data logging with my Accessport. I've noticed the coolant temps never go over 230F. This was the same before the install as well. Ambient here is in the 80s. So far the FMIC is doing a great job of keeping intake temps down. What I've noticed in the data logs is that before the install when under peak boost the intake temps would climb to +20 over ambient. With the Helix the temps actually drop and are usually about +5 over ambient.
Here's a pic post install.
Old May 5, 2013 | 08:04 AM
MikewithaMini's Avatar
MikewithaMini
I haven't noted any change and I have an OBDC gauge. It will be interesting if there is any difference in coolant temp in the Texas summer, but I doubt it. The fan will come on earlier and run more from ambient temperature but I doubt that the minor obstruction an FMIC represents is significant, guessing.... And how could you tell?
Old May 5, 2013 | 08:55 AM
Carey P's Avatar
Carey P
I just installed mine from the last group buy and did notice an immediate affect on the fan running more. It doesn't run that long after turning off engine and I'm not too worried about it yet. Of course, it's only in the 90's so far and will be interesting to see how it goes during the 110deg months. I haven't monitored coolant temps though I do have an AP.
Old May 6, 2013 | 10:44 AM
myR56S's Avatar
myR56S
I run a ALTA FMIC and I have seen no issues. This will be my second summer with it and if there is any change the fan might run a little longer.
Old May 13, 2013 | 08:11 PM
bimpower's Avatar
bimpower
Installed the Helix over the weekend and have edited first post with my findings...
Old May 14, 2013 | 09:16 AM
cesar418's Avatar
cesar418
Do you have an open cone intake? I wonder how the numbers will change with an open air intake
Old May 14, 2013 | 09:17 AM
bimpower's Avatar
bimpower
I have the stock intake.
Old May 14, 2013 | 12:13 PM
bmx045's Avatar
bmx045
I wonder if installing it without a tune would be okay? other than needing a little more wastegate duty cycle, the charge temps will be lower so it will stave off detonation more than oem....nor would the car run leaner with a bigger fmic.
Old May 14, 2013 | 03:33 PM
Ch28Kid's Avatar
Ch28Kid
Install without tune is absolutely ok. I installed it when I had my JCW Tuning Kit map and definitely notice huge difference.
As for water temp, it's exactly the same according to my scangauge. It tops at 105 C (221 F) with and without FMIC.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
point665
Sep 29, 2015 12:41 PM
