R50/53 Loss of Boost
Old May 1, 2013 | 02:50 PM
ishoelaceee's Avatar
ishoelaceee
Loss of Boost
I went to the track the other day and did 4 passes down the drag strip. The car ran good and I didn't notice any problems. After wards I was driving home and stepped on it and noticed my car was only spooling 10 pounds of boost. I have a 17% pulley reduction DDM cold air intake and an exhaust. My car always runs 15pounds of boost. I don't know where my 5 pounds of boost went lol. I have ruled out engine problems with a leak down test all 4 cyl were under 10% leakage. I have also ruled out the gauge being faulty . It is a new automated gauge that has been reading fine. I hooked up a known good gauge and also hooked up a fuel pressure gauge they both said 10pounds. I am not sure what else to check . 5 pounds is alot to lose. Any ides would be great. The car is an 03 MCS with 80,000 miles.
Old May 1, 2013 | 05:33 PM
GreekDrifter91's Avatar
GreekDrifter91
check all your lines, and maybe your bypass valve is open slightly leaking boost.
Old May 1, 2013 | 07:28 PM
ishoelaceee
I know I don't have a vaccum leak for sure. But I ordered a Detroit tuned bypass valve. I'm going to see if that fixes the problem or not. But I was wondering if it would be that my belt is slipping at high rpms. Is that a possibility?
Old May 1, 2013 | 07:42 PM
ZippyNH's Avatar
ZippyNH
Yes...
you can usually hear a squeal if it is bad....
But I was at a dyno day, and Jan of RMW looked at the graph, and could tell a belt was slipping BEFORE it was bad enough to squeal...
General rule I think....
New belt yearly with a 17%
every 2 years with a 15%
and always use the right belt...a stock JCW belt COULD be used for a pulled car...they were used early on in modding, but better options are available...when a belt as long as the stock or JCW one stretches JUST a BIT...they start to slip very fast!
It is EASY to ZIP tie the bypass valve shut to test if the bypass valve is faulty....but you are getting a new one...so just wait for it and install it once IMO.
Old May 1, 2013 | 07:45 PM
ZippyNH's Avatar
ZippyNH
Have you looked at your SC boots?!
They rubber tends to get harder as they age.....then they can leak and split. New ones are about $75-80 from Waymotorworks.....
Look for oil seepage around the boots...this is one time that the PCV gasses that condense in the IC is useful....
Old May 2, 2013 | 10:58 AM
ishoelaceee
Are you talking about the two rubber boots that go onto the intercooler? Or is there some other component that im not seeing ?
Old May 2, 2013 | 11:03 AM
ZippyNH's Avatar
ZippyNH
Yup...those rubber things on the end of the IC.
Old May 2, 2013 | 11:09 AM
ishoelaceee
I'll look at them I had them off not to long ago to hook up the boost gauge and they looked and seemed to be in hood shape.
Old May 4, 2013 | 06:22 PM
ishoelaceee
Just got done putting the DT bypass valve in. There was no change in boost it is still only spooling 10 pounds . Any other ideas? I'm running out. I think I am going to buy a belt tensioner and a new belt.
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
paul7878
Sep 14, 2015 07:44 AM
